Turbo troubles
Re: Turbo troubles
No mate, but I'll be having a proper look at the car in the next couple of months. I'm thinking there's something wrong with the wastegate - either it's stuck open, there's a leak in a vacuum hose or the vacuum valve is toast
- Site Admin & Mad Biker!
Re: Turbo troubles
I'm really glad this post popped up as I hadn't spotted it before, some things to check on mine as well.
It's a shame niz has done a disappearing act
Re: Turbo troubles
May be us 3 should meet up and have a turbo fixing day lol
1997 2.0l turbo executive 150bhp P--- BUD
Re: Turbo troubles
Might not be a bad idea actually!TehAgent wrote:May be us 3 should meet up and have a turbo fixing day lol
I think mjb is more interested in sorting the clutch on his coop at the moment though
Re: Turbo troubles
whats a big problem for me too ...teamster1975 wrote:I'm really glad this post popped up as I hadn't spotted it before, some things to check on mine as well.
anyway changed turbo last week, bought second hand... Changed it.. Found manifold loose, took all nuts off by hand (so why my old turbo died...)
it took about 8hrs to get out from my car. It worked good, i thought i got hybrid t25/28 turbo. But after week it doesnt seem the same power, looks likes boost disapearing...
checked near no. 5(right one) hose is loose and it sucks air.it could be the problem ? i think i need new throtle body...
thanks guys for any info
P.S. who owned P361 MJW white 4dr ???
Re: Turbo troubles
OK i have a naff actuator, mines stuck open, had a look at a activa turbo CitroJim from the frenchcarforum has on his work bench today, and the arm on that has to be pulled out of the actuator to open the waist gate, where as on mine its the opposite, i have to push the damn thing in to the actuator to get it to close.
Annoyingly looks like the breakers yard in Northampton have changed their opening days as it was closed when i got there, other wise i would be stuck under a car getting me parts. looks like its going to have to be sometime tomorrow then. ill see if i can get that pipe if its in good condition as well.
- niz406
- Admin <BR>Turbo God
Re: Turbo troubles
Niz hasn't dissapeared.... lol
Re: Turbo troubles
Good to see you Neil!niz406 wrote:teamster1975 wrote:I'm really glad this post popped up as I hadn't spotted it before, some things to check on mine as well.
- niz406
Re: Turbo troubles
Well I saw my name mentioned and thought..... time to step in and speak out ;) lol
Re: Turbo troubles
teamster1975 I've been over the scrappers today, had a look, got a working actuator that i need to claim before they crush the car (forgot i emptied my tools from the boot due to the misses wanting to do shopping
) and they have that pipe of yours too
so I've hidden it and will grab it Wednesday when i head back over for my actuator.
Re: Turbo troubles
For diagnosing boost issues, a boost gauge is invaluable...
Wastegates rarely cause problems but actuators do. Sometimes they seize up, or the diaphragm splits inside. Although neither is really that common. The do lose tension over time so its worth nipping them up a bit if your ever in that area. I did the same to mine last week and i get only a 1psi boost drop at the top end, which is excellent for a small turbo on a big (ish) engine!
2000 Xantia Activa CT Turbo
1990 MG Maestro Turbo
Re: Turbo troubles
Did you ever get a chance to pick this up? I missed your reply, sorry! No worries if notTehAgent wrote:teamster1975 I've been over the scrappers today, had a look, got a working actuator that i need to claim before they crush the car (forgot i emptied my tools from the boot due to the misses wanting to do shopping) and they have that pipe of yours too
Re: Turbo troubles
I've been thinking the same myself... Does anyone know the measurements of the vacuum pipes for getting the right T-pieces?Xantiaman wrote:For diagnosing boost issues, a boost gauge is invaluable...
Re: Turbo troubles
Turbo?
v6?
Planning on getting your money's worth out of the new clutch?
v6?
Re: Turbo troubles
Boost gauge kit usually comes with a T-piece. Mine is t-eed into vac pipe to ECU, just before the fuel vapour/oil trap. Best spot IMO, as this is what the ECU is seeing and they can be quite fussy sometimes near the boost cut.mjb wrote:I've been thinking the same myself... Does anyone know the measurements of the vacuum pipes for getting the right T-pieces?Xantiaman wrote:For diagnosing boost issues, a boost gauge is invaluable...
