Also another quick question gonna be doing a box oil change too, I have 2 litres and think I have read it holds 2 litres, does that sound right?
Thanks for the help
Chris
martint wrote:Is it not 1.6litres? Maybe wrong tho. Google it. Or service box
Sealant's not required. I've never heard of problems with the fake (rear) coil pack or HT leads on these cars - just change the actual coil pack. Be aware the allen bolts holding it in are going to be *TIGHT*. Best to have an impact driver to hand if you don't want to round the bolts.randomcaller wrote:Hi all I'm going to be replacing both coil packs, sparks and ht leads on my d8 v6 engine as its missing under full throttleanything I should be aware of that might hinder me? I'll get a new inlet manifold gasket and sealant but is there anything else you guys know of?
It's 1.9 litres. Easiest way to fill up is by removing the reverse light switch (under the air filter box, grey connector) and pouring it in there.Also another quick question gonna be doing a box oil change too, I have 2 litres and think I have read it holds 2 litres, does that sound right?
