EGR VALVE??
dervpower
2.2 16v
EGR VALVE??
Post by dervpower »
has anybody removed or blanked off their egr valve does it improve performance at all?
turbolag
Officer of the law!
Post by turbolag »
Yes. No.
Though it's a troublesome part and worth doing for reliability purposes, especially on an XUD.
niz406
Admin <BR>Turbo God
Re: EGR VALVE??
Post by niz406 »
dervpower wrote:has anybody removed or blanked off their egr valve does it improve performance at all?
Doing so will result in a number of Error Codes and Engine Check messages / Light !
Niz406
jameslxdt
Post by jameslxdt »
only on a HDi
niz406
Admin <BR>Turbo God
Post by niz406 »
On any car after 2001 when OBD2 was a basic requirement for emissions monitoring and fault notification!
Niz406
niz406
Admin <BR>Turbo God
Post by niz406 »
Then obviously peugeot have not implemented the monitoring specification properly, missing flags and all that !
TUT TUT !
Niz406
turbolag
Officer of the law!
Post by turbolag »
No error codes, if you physically remove and blank off the EGR actuator itself, but leave the contoller/servo thingy plugged in with the outlet vacuum pipe plugged. Even if you remove the servo doodah, you only get a stored fault code and shouldn't (so i'm told!!!) have the EML lamp on the dash coming on.
On the HDi the unit is prone to clogging, and on the XUD it causes localised hot spots in the head which can lead to cracking, so its worth the effort to at least disconnect it.
dervpower
2.2 16v
Post by dervpower »
can a blocked egr valve hinder performance?
dervpower
2.2 16v
Post by dervpower »
dervpower
2.2 16v
Post by dervpower »
might try cleaning mine out then as i have to renew inlet manifold stub gasket from when i did intercooler mod bitch of a job though especially with my sausage fingers!!!!! which part do you clean out??
On the 2.1TD XUD engine the EGR valve itself is behind the engine and is a pain to get to.... unless you remove the inlet manifold...
nutski
Post by nutski »
Captain Jack wrote:On the 2.1TD XUD engine the EGR valve itself is behind the engine and is a pain to get to.... unless you remove the inlet manifold...
Arse, thats what i`ve got :)
What exactly do you block off through?
pugsport
Post by pugsport »
is this the same valve that caused major probs with the renaults and gave the mechanincs severe depression and the owners turned suicidal?
MODIFIED 1997 406 SRI; FULL ECOSSE TOURING BODY KIT;CUSTOM EXHAUST;
17"FOX ALLOYS;DUMP VALVE;
INDUCTION KIT;LOWERED 40MM.
LEXUS STYLE REAR LIGHTS;
DTM STYLE MIRRORS
