I'm liking your positive attitude Capt Jack
Captain Jack wrote:Wiggy, look on the bright side:
sirwiggum wrote:I tried to change the COM2000 and ended up with a soldering iron fixing the airbag connector clips, and the airbag ECU holding clip broken.
At least you honed in your soldering skills.
I'll grant you that, hadn't soldered since school so was surprised it worked!
sirwiggum wrote:I tried to change the oil and ended up draining the gearbox
The gearbox was treated to new oil - never a bad thing.
This is true, and I was chuffed that 406 gearboxes have an easy-fill breather!
sirwiggum wrote:I tried to get rid of some rust bubbles on the passenger doors and ended up with several shades of blue.
But no rust.
After the winter the rust was back with a vengance, and my nearside doors were a mix of blue, part of why I wanted rid of it.
sirwiggum wrote:For the handbrake I left the 406 in to a garage, £300 later had something that just about worked.
Er... OK no positive here but mine can hold a lorry after replacing the shoes and the seized cable.
Well the positive was that it got through an MOT, and stopped rolling forward into the front doorstep at night!
