!BREAKING! 1996 406 1.9td lx saloon green
Does the throttle linkage happen to involve a short threaded rod about 3 inches long with a ball joint at each end?
jameslxdt
Post by jameslxdt »
if its for a d8 all the accelerator cables are the same
jameslxdt
Post by jameslxdt »
No mate, I'm referring to a linkage under the bonnet near where the accelerator cable terminates
jameslxdt
Post by jameslxdt »
does it look like anything on here:
Nice CD-ROM... where did you get it?
No mate you're completely misunderstanding me. I'm after the linkage between the end of the cable (near part 7 on your diagram) and the throttle body
Seeing as you have the cdrom, look at "14N Intake manifold air distributor" and then click the first - 14N01A. The part I'm after does the same job as part 17 except it's not bent. See part 2 at the top of the diagram? It's like one of those with a pair of plastic ball cups stuck on the ends. I should probably grab a photo later today
