now im having trouble finding a garage local (brum/cov) that will fit it,
they are demanding i use a DMF and use there parts
so does anyone, know where i can get it done,
id do it my self but im getting to lazy
that would be bad clutch alignment,Gary406 wrote:sure sum1 on here posted a problem he had with his solid conversion
he had a bad judder in 1st gear , have a search through the forum im sure its in here sumwere
if you are in south wales i know a garage that'll fit it, mine lolgeneralbaxter wrote:tbh it really needs changing 150k, on its orginal clutch
I can remember from the Mondeo forums that it was mainly a refinement issue.M<ost of the guys that did the conversion found that it was a little more rattly & a bit more juddery on pull away, but the conversion was much more commonly done with the Mondeos as the clutches weren't lasting that long. My TDDi had the clutch replaced at 70k & before I bought my Pug I looked at a TDCi with 85k & a knackered clutch. Foot down at 35mph in 4th & the rev counter went mad. Salesman tried toi tell me that it was because there was so much power & that it had a recent clutch. Must be some power to make it wheelspin in 4th & even then, the speedo would've gone up by a bit...Gary406 wrote:sure sum1 on here posted a problem he had with his solid conversion
