what freq shall i set HP filter to on headunit?
ive got a pioneer headunit and standard 406 components, ive got my alpine sub set to 80hz, what shall i set the hp filter to for the other speakers? can they handle 80hz?
Re: what freq shall i set HP filter to on headunit?
my 4 channel amp that powers my 4 music speakers is set to about 100hz
my other 4 channel amp that powers my 2 subs is set just under 100hz
subs set to low pass means everything under 100hz goes to the subwoofers
4 music speakers set to high pass means everything over 100hz goes to them
you want your hz set to the same around 80-100hz but obviously set the high and low pass filters to suit the music/sub speakers
ye your components handle everything over 100hz,
your head units high pass filter set it to around the same as your subs setting, i just use 100hz
the proper way of setting them up is you want your head unit on full volume setting 1st, turn all amps down , once the volume on the head unit is almost at max you then adjust the input level on the amps,
is 100hz not high for a sub?
if you ever get stuck mate give us a ring,
07856 431 948
07856 431 948
nah 100hz isnt to high,
my subs have a frequency range of 28hz to 450hz
but some of these frequencys the subs cant play anyway
ive got an alpine type r in an alpine ported box, ill set it to 100hz tomorrrow and see if it sounds better.
my headunit lets me set the lp aswell, i dunno which one to use, spose set it to 100 hz on the amp and 100hz on the headunit, if that doesnt mess up the amp settings
i'll post a pic 2moro of my setup.
but heres a short list
alpine 9855r head unit
JBL GT5 A604E 4 channel amp (for 4 music speakers)
JBL GTO 1004E 4 channel amp (for 2 subs)
2x JBL GTO1202D 12" subwoofers in a double sealed enclosure
Planet Audio Big Bang 6x9s in the shelf
Planet Audio Big Bang 16cm Front Componants
3.5 farad power capacitor
leave the headunits LPF off if your using an external amp to power the sub
im just finding the vocals arent as loud as i thought theyd be running off the headunit, prob the sub drowning them out,
yes that what happens thats why i use a power capacitor and a external amp to power the music speakers
if you think of it this way its easier to understand,
you have a external amp powering a sub ,
and the head unit powering the music speakers,
the head units small amp cant keep up with an external amplifier, theres no comparison
so to get right you have to turn the subwoofer down so they all play at the correct level and sound good together
i just set it all to 100 hz but i cant turn the lpf off on the headunit so i set that to 100hz aswell, and you can adjust the level of the sub on the headunit so you can have the speakers louder or visa versa, i need to get some good components, just need to ger my head round that iso procedure
