306 GTI-6 Pads
ally406
306 GTI-6 Pads
Post by ally406 »
Has anyone tried fitting these to a 406? Some manufacturers list the same pad for both, some have different part numbers. Some have a pad that is 3mm taller for the 306 compared to the 406 but other dimensions are the same. There is a far better selection of performance orientated pads for the 306 than 406. I think they will fit, but has anyone had any experience of this?
dirtydirtydiesel
Re: 306 GTI-6 Pads
Post by dirtydirtydiesel »
Why bother mate, EBC do there green, red & yellow stuff pads for this car. The Reds are cracking fast road pads.
pug406nz
Re: 306 GTI-6 Pads
Post by pug406nz »
306 calipers are different to 406 calipers, so I wouldn't risk buying a set to find that they dont sit nicely. I would only suggest you buy uprated pads if you were going to do racing or track days and if you are, I would suggest you do a 406 coupe brembo conversion on it to get some proper braking instead of uprated pads on lucas calipers.
ally406
Re: 306 GTI-6 Pads
Post by ally406 »
Apart from the obvious benefits of having better brakes, I'm going to be using the 406 to trailer another car to the track, so in light of towing a large heavy trailer, I was looking into uprated stoppers. My choice is usually DS2500 which last I looked weren't available in 406 fitment, but seem to be now, so no problem. Likewise I didn't realise (largely due to EBC's terrible catalogue) that red and yellowstuff were available, so more options.
dirtydirtydiesel
Re: 306 GTI-6 Pads
ally,
ebcbrakeshop.co.uk
Part Nos,
DP 21047 greenstuff
DP 31047C redstuff
Both of these are for a 110 front fitment with Girling calipers
Hope this helps DDD :cheesy:
ally406
Re: 306 GTI-6 Pads
Post by ally406 »
Cheers mate, EBC seems to be the way to go and not too expensive.
Re: 306 GTI-6 Pads
EBC is good stuff,
less dust on the alloys with these, ifind they take an age to bed in unlike other pad's
good value for money tho .
