Hi guys, this is my first post here so please be gentle!!!
I've had my 406 Executive D8 for about a year now with no probloms (touch wood) but while hoovering out the boot this morning I came across a lock on the offside rear of the car, just behind the light cluster.
The lock is inside the boot, when I brought the car the owner said he had an extra key with it but he didn't know where it fitted.
All this seems to do is: set one way, when I deadlock the car with the small button on the keyfob, it just locks.
When set the other way it deadlocks the car and then the car emits a loud "BEEP".
Can anyone help me with this?
Thanks guys
Unknown Lock In My Boot
- niz406
- Admin <BR>Turbo God
Mjb is right, its to turn off the self powered siren to avoid the thing going flat when you disconnect the battery...
If you lose the key, a flat blade screw driver works just as well..........LMAO
If you cant find it then the cover must still be on yours Mjb, its got a cap over it from new and you have to pop it off !
