selecting gears
Archangel
selecting gears
Post by Archangel »
my 406 is difficult to get into gear even when stationary, 1997 1.9 diesel, any info appreciated
Replacement !
johnboy
Re: selecting gears
Post by johnboy »
Could be synro in the gearbox on its way out or a worn selector rod?
jasper5
Re: selecting gears
Post by jasper5 »
If the gear selection is fine when the engine is off the problem is connected with the clutch, either cable problems or hydraulic problems depending on your operating system, if there appears not to be any cable or hydraulic issues, the problem probably lies with your clutch (collapsed pressure plate or broken spinner...possible bearing fault as well).
roton600
Re: selecting gears
Post by roton600 »
The mechanic who changed my clutch recently said that its normally the clutch plate "dragging"(worn) that makes it difficult to get in gear. Get it checked out soon, or the gear linkages will probably come off and leave you without being able to select any gears. (see one of my posts) Do you know how many miles the clutch has done? Dont use Mr Clutch for a replacemant.
