How to change wingmirror?
sockpuppet
Post by sockpuppet »
Hi there, ive got a replacement OS wingmirror for my D9 406, but ive never done this before, how exactly do i remove the old one and fit the new one?
thanks
406 2.0 HDi Rapier, 2003 plate
Re: How to change wingmirror?
Three torx screws - one behind a small round cover on the door card and two behind the little triangular bit of plastic, which you push upwards as far as I remember.
You have to gently lever off the triangular plate, it can be a bit tight.
Lower the window to make your life easier!
Then as Steve says 3 torx screws. I'd use a magnetic screwdriver as they like to drop in the door!
Good point, especially the one through the door card :roll:
pugagain
Post by pugagain »
Once you have undone the screws, the mirror comes away easily. The cable pulls out a little bit but you have to release he catch on the plug to release the old mirror. The catch is at the top of the plug. You have to find the catch lever and pull it "over the top" of the plug assembly. It is hinged at one end. Easy to do once you find it, but need to look hard to find it
Current: 2003 406 D9 SV V6
Previous:
1999 306 XR
1981 505 XR
1969 404
Top tip:
Windows down - catch it with both hands so you don't wreck the paint work. :cheesy:
