D8 mileometer and clock illumination?
- Newbie
Morning all, anyone help with this one?
The illumination for my 1998 Exec dashboard clock, and mileometer/odometer went recently at the same time, although both displays are working if you peer at them very closely. I tried replacing the clock with another, same problem; and also replacing the clock bulb but it makes no difference. The clock works but it doesn't illuminate. Before it conked out completely it did work a couple of times if you banged the dash above it (the clock).
I did actually have a hand control fitted just before they both went out, but I can't see what could have happened here or if it's related.
Ta!
Ta!
Re: D8 mileometer and clock illumination?
are all the clock lights dim or just the two?
- Newbie
Just the digital clock on top of the dash, and the dual mileometer/trip meter under the speedo. The actual dimmable dashboard display (rev counter/speedo etc) lights are fine.
- 2.0 Turbo
i know this might be a daft question have you tried the fuse
Ahh, percussive maintenance, I love it. That'll be a dodgy connection then.carlo14 wrote: ...it did work a couple of times if you banged the dash above it
- Newbie
Not the fuse, checked that.
- jbh325i
what fuse does the mileometer/trip meter as mines isint lighting up either
1999 406 glx 2.0 HDI 110bhp
1974 BMW 2002
1974 BMW 2002
- Newbie
Hi all
Can't help on this but have a problem on my 1997 406 estate petrol 2L. The speedo and rev counter are both on the blink except when they decide to work. I also have problems with only some of the lights working the rev counter and speedo but these never work. If I whack the top of the dashboard, i can sometimes get the speedo to work!!!
Any ideas?
Just joined so newbie so please go easy!!!
Alan
Any ideas?
Alan
I think there is a common issue with bad solder / dry joints on the rear of the clock panel. Ill be removing mine soon too - similar issues and speedo works whenever it wants.coolverbatim wrote:Hi all
Any ideas?
Alan
- swiss
Certainly the operation of dash gauges can be affected by dodgy French soldering. Whacking the dash is a temporary fix, more long term you need to pull the bastard out, split the cluster right down to expose the PCB and re-solder every single joint without soldering in any shorts
I've not heard of this fault affecting the dash/clock illumination before. When I've had lights out, it's always been the bulb - thus far. My clock light is out at the moment, so if/when I get off my arse and fix it I'll let you know what'd happened
The man with no car
