are the high pressure air con pipes very expensive for D9's? 2.0 Hdi if that makes any difference
had my air con looked at today and the high pressure line that crosses over the low pressure line at the front has developed a leak, i saw it for myself
Any chance of a picture ? if its one of the 2 pipes that go under the battery tray and
at the back of the brake servo then into the bulkhead these come as a pair £68 i had
mine renewed at main stealers , the pipes replaced system re-gassed £300
could be cheaper if its one of the other pipes .
i might just pay someone else to do it if its a fiddly job i hate them kind of jobs, last thing i did on mine was a broken suspension spring, which was pretty annoying because i needed to use two sets of spring compressors becuase the spring was huge and 1 set wasnt long enough...took ages
yeah, you're right, i think its more that its having to pay it, it caught me by surprise, ah well, it'll be worth it when its done, especially if the summer is going to be as hot as people are saying
Welton wrote:Unless you already know this the 406's air con is WELL worth having - it's brilliant
How does the Volvo's compare Welly?
