So of late I've been driving everywhere as grandad-like as I can but today I was in 5th gear, 1500rpm, gave it slightly too much throttle trying to keep up with a 1.1 fiesta and it slipped
So it's got me thinking since I can still get about sharpish in low gears when the ol' red mist descends ... Would it not help prolong the life of the clutch if I went everywhere around 5000rpm (accelerating slowly) instead of trying to keep revs as low as possible?
Welton wrote:I would probably amble about town in 3rd mostly, say around 3000 rpm....try it and see if it helps?
That's about 50mph, not quite ambling
Drove to work this morning only using 1st and 2nd. Pedal feels so horribly vague and slow, but I didn't really feel it slipping while in gear. Think I'll be heading down to Wolverhampton in 3rd ;)
Speaking of prolonging clutch life. Could anyone tell me the difference between this (a HDi 90 clutch) and this (a HDi 110 clutch). If the 110 clutch is built stronger to take the extra 20bhp of power, i'll get one of those.
HI,
Not that I've had the problem ..yet. Apparently D9 clutches arent as good as D8's.
Five people up and going around North Wales all the time would you think cause problems but I'm hoping that mine will last.
On the D8 1.9 I changed the clutch as a precaution when the gearbox came out for a bit of fettling at 200k.
The replacement Valeo clutch is still working well in the car 240k on and thats had solid urban taxi work inc the North Wales hill runs. Compare this to my old Montego diesel which went through a total of four in the same mileage!
I believe that the thing (told by old mechanic)that wears clutches out are sharp fast starts and rough gearchanging and clutch riding. Smoothness it would seem is the key.
