where does the cd changer fit on 406 est.
my 2002 estate has a sat nav unit on the drv side in the rear panel. the passg side panel looks like its designed to take a first aid box? can i fit a cd changer ? ie is the wiring plug present and if so where is it ? thanks.
- DaiRees
Re: where does the cd changer fit on 406 est.
Yeah that's where it goes, behind the left hand panel in the boot. Dunno if the wires will be there or not
, sorry mate.
Hang on, you've got OEM sat nav but no changer?
Strange
is that odd ? when you say left panel you mean passenger side ??
Open the tailgate and it's a panel on the left. There should be a cD changer in there. If there's just a cage then the changer's been removed previously and there should be a loose connector floating around somewhere
Aww, that cracks me upalladdin wrote:is that odd ? when you say left panel you mean passenger side ??
My mom is the same way. Every time we try going to the country side for weekends or sumthin, on the way she allways asks " my left or your left"
But jes, MJB-s right you know. I 2 have fliped through the users manual and if you have bit better Pug than the basic then on the left it should be
Peugeot 406 Break - 2.0L - 99kW - EW10J4/RFR - BVM5 - VF38ERFRE80937145
