The PC2-36-AMP is a 2-socket ISO connector, with the 4 speaker lines (8 wire ISO connector) leading to 4 line-level RCA jacks via smoothing capacitors and the 7-pin power ISO block going straight through to the HU ISO connector. The power block needed re-wiring so the aerial (amp remote switching), ground, +12v switched and +12v non-switched were connected right, and the 3 other wires (VAN bus power/data1/data2 - so much for standards eh Frenchies?
According to the Haynes BoL, one chunk of the wires on the mini-ISO block I've left disconnected go to the changer, and another chunk go to a "suppressor".
Does anyone have any idea how this "suppressor" works or even where it is? With the amp powered up and the speaker lines completely disconnected, I still get the buzz and whistling, although not with the OEM head connected up properly, so I think I may need to activate this suppressor thing somehow... ideas?
Otherwise I'm going to rip the JBL amp out (not overly impressed with the sound quality anyhow, it appears to do some iffy filtering) and find some way of amping it myself. Eventually. How would I go about this, as there's 8 individually wired speakers in the car (4 tweeters, 4 woofers), and all the amps I can see on ebay seem to be 2/4/6 channel
Who's got some suggestions on crossovers and amps?
I want the speakers running as flat a frequency response as possible while spending as little money as possible... That means anything that emphasises "bass boost" is likely to sound repulsive to me. Massive amounts of volume aren't required, and while I know I could just slap some crossovers in the back and run them from the stereo's speaker outputs, I'd rather amp it as the head unit can overheat in summer
