help need how do i take off my alternator on a 2 litre turbo
dragonslayer
Re: help need how do i take off my alternator on a 2 litre turbo
Post by dragonslayer »
all sorted with the alarm its just that the battery isnt charging with the alternator
dave
dragonslayer wrote:alternator i got off ebay.its charging a bit but not a lot with the lights and blower on it goes down to 11.97 volts
hope its not the alternator again.as i dont really want to change it again
dave
I bought mine from Eurocarparts, £140 off the top of my head including surcharge for old unit. I know the tubby draws a lot of Amps, have you got a link to the auction Dave?
mjb wrote:That still leaves the alarm active in other ways - the locks and disconnecting the battery will still set it off
There's something else you can do with the button to cause the entire system to deactivate
I think by pure fluke and faffing around I ended up disabling the whole lot anyway Matt! I miss the plip though :cry:
dragonslayer
here is the one i got off ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0133599717
dave
I've got a horrible feeling the one you've just bought is no good, I reckon the regulator has gone iffy; you'll probably find it puts out 14v over 1500rpm or so. Stick a meter across the battery & rev the engine up to see if you start getting a charge.
dragonslayer
thats the first thing i did and im getting a bit of charge
dave
I think you're going to have get another alternator :(
dragonslayer
cant i repair the alternator
dave
dragonslayer
hi i havent put the other alternator on the car yet but its off a 1.8 and a guy at the scrappy said a 1.8 would fit
my 2 litre turbo petrol
dave
dragonslayer wrote:hi i havent put the other alternator on the car yet but its off a 1.8 and a guy at the scrappy said a 1.8 would fit
dave
Fit? Maybe
Provide enough power for without blowing up? Probably not
dragonslayer
so your saying it wont fit or work
dave
The lower rated alternators (apparently) have one less rib on the output pulley so the aux belt won't fit correctly.
Most importantly the tubby exec draws more current than the 1.8 so you'll fry an under-rated alternator.
dragonslayer
hi just put the 1.8 alternator on its charging the battery so im happy.charging at 13.20 with the lights on
also the tensioner i need a new one as where you but a rachet its broken
dave
