JVC KD BT11 Wiring
dave2103
JVC KD BT11 Wiring
Post by dave2103 »
Hello to everyone on here, this is my first post.
Car is W reg 406 HDI saloon.
I hope someone can help here, Ive put the JVC KD BT11 stereo in yesterday & am having problems with the usual constant live feed.
I've looked at other posts & have tried the shunt method but I thimk it was in the correct position in the first place, after moving it, all sorts of things decided not to work so I put it back as was! (in the photo)
The only other thing I can think is the ISO adaptor loom but not too sure which ones to move.
Also put a pic of the adaptor.
Re: JVC KD BT11 Wiring
You should never try any D8 electrical fixes on a D9 - pretty much everything is completely different and you run the risk of damaging the BSI
The adaptor pic appears to be a black blob with some wires coming out of it. Did it come with the stereo, is it an extra specific to it or is it part of the car? By the way don't guess with this one, some of the wires feed directly into the BSI...
Hi Dave,
I've got a list of the original D9 audio connectors / functions. Let me know if this is would assist you.
Can't help directly with your JVC unit, but if you can provide the info, or a link to it, I'll try to suggest a solution.
dave2103
Post by dave2103 »
Hiya dogslife, sorry not got back driven up to Manchester today. That would be a great help mate, steve_earwig, it's the conector block to the iso plug for the head unit, not a great photo! gonna get a multimeter tomorrow to see which is the constant live feed & which is the ignition live. I always take the facia off every night so battery drain shouldn't be an issue.
http://resources.jvc.com/Resources/00/0 ... 6-002A.pdf that's the PDF for the instalation.
Thanks.
ianst28
2.2 16v
Location: sunny wirral (who am i kidding it's always bl&^%y raining)
Post by ianst28 »
just a quick thought
have a look at the back of the jvc and see if the fuse can be fitted in 2 places ........... this is kinda hard to explain with out pics but i'll try
on some jvc units you can move the fuse up or down a socket this switches the permanant and switched live ...... this is ideal if your car (usually a poxhaull) has the permanant and switched live in opposite places to the standard iso wiring on the jvc and means that you don't have to buy an adaptor or mess with the wiring on the cat or the lead to solve the problem
hope this helps.................... actually really i just hope it makes sense to someone .................. it all made sense in my head lol :idea: :idea:
If at first you don't succeed, skydiving is not for you !!!!!
Hello again Dave, (sorry I 'lost the thread')!
Car harness, ISO connector, Power side (Black):
Pin 1 (black) - phone mute input
Pins 2, 3, 4 - Vehicle Area Network, (Can bus comms), don't connect anything to these unless you're certain you know what's what.
Pin 5 ? (not used on mine).
Pin 6 (yellow, marked AH25B) - switched live - the same function as red wire (3) on JVC connector
Pin 7 (mauve, marked BH10A - permanent live - the same function as yellow wire (2) on JVC connector
Pin 8 (green/yellow, marked M841 - earth - - the same function as black wire (1) on JVC connector
That leaves wires (4) & (5) on the JVC connector, (4) is there to work an electric aerial etc. so you shouldn't connect it.
(5) orange, illumination - I think most people connect this to the illumination lamp for the ashtray or cigar lighter. TBH I'm not certain of its function, it could be to supply the fascia illumination of your head unit, or to dim it down when the lights go on.
The other half (yellow) of the Pug ISO connector has the 8 connections for the 4 separate speaker circuits. I'm fairly certain these are genuinely standard so should just plug in OK.
Again sorry about the delay & hope this helps
HimBigChief
Post by HimBigChief »
As said the lead you've got as (4) can also be used to turn power amplifiers on, if that's your sort of thing. The other wire (5) is usually connected to a wire which changes voltage when lights are on. This tells the stereo that the dash lights are on so dims the display. Without connecting this wire the stereo will stay the same brightness day or night. So basically you had the right idea!
Image Image
