1999 XU7JP4 D9 406 1.8 lx 16v Cable clutch.
I have just paid £167 to have the rear engine mount replaced. I have already replaced the top two mounts and thrown in a new clutch cable for the fun of it. YET! I still have the judder problems when pulling away in first gear so I can safely say for sure that my clutch/release bearing is buggered. In fact I am now pretty certain its the release bearing as I can hear a slight grumble when sitting idle which goes away when I press the clutch.
As mentioned in a post a while back, the cheapest clutch replacement quote came out at around £370 which was from Mr Clutch - the previous owner used them to replace the clutch 20,000 miles ago, so I am reluctant to take it to them again if its just going to wear out quickly. I want to replace it properly which means paying for the privilege and with decent garges quoting between £550 to £640(main dealers), that is a big hit for a clutch kit which costs £70! The car isn't worth £640 but it is also not worth selling for the sake of a £70 part! I also cannot stand paying someone to do a job I haven't even attempted to do. (see note above on £167 rear mount! That really is a git to remove! (First defeat ever!))
Looking though haynes it all seems pretty straightforward to remove the gear box and then replace the clutch and bearings. I have changed CV joints before so removing the drive shafts shouldn't be a problem. I have all the tools and nothing sounds too much of a challenge in theory. I consider myself a competent diy mechanic.
So... is it really that bad? People keep saying you have to remove the subframe, but there is no reference to that in the haynes book. Is that true?
What could go wrong?
If I go for it, what should I change whilst I have everything apart? - inner cv joint covers, oil seals?
Any pointers such as - "better you than me", or "go for it, its an easy job" would be most helpful! I would plan to do this over a few days taking it slow and easy - one day remove gear box - next day do clutch and put it all back together again etc.
Any advice would be great.
Thanks for reading.
