birds chirping in the engine bay ?
- Newbie
hi guys - new to this site so please bear with me..its seems that i can hear a lot of rattling, chirping noises come from the engine bay when im moving off...it seems to get more worse when im turning the steering....when the car is parked up and engine is running, if i locke the steering to the left and the right...this rattling chirping noises increases...im assuming its something to do with the PAS, belt, pulleys.....?, oh its a high mileage 1999 peugeot 406 90bhp hdi..cheers
Re: birds chirping in the engine bay ?
I would have a look at the long drive belt on the left. The floaty/bouncy tensioner at the top is expensive but mostly the whole lot goes quiet when you just fit a new belt
Also check the level in the PAS bottle (might be running low).
Not sure if the 90bhp model has a dampened botom pulley? but this is well loud when this gets going
- Site Admin & Mad Biker!
It could be the power steering pump bearings on the way out; mine is making similar noises.
Get a long screwdriver and put the tip on the pump and your ear to the end of the handle; you'll know for sure where the noise is coming from then! Get someone to turn the steering wheel lock to lock while your listening.
- Newbie
thanks guys...will get a mechanic to look at it, dont know much about mechanics myself, i just get worried being ripped off....lol, also the antiroll bar linkage balljoint is making a knocking noise when i go over bumps...so what am i expected to pay to have the antiroll bar linkage ball joint changed and the big long belt?...ta, just so i can get an idea of what to pay...
