High pitched whine on acceleration in all gears
- Newbie
I love the Peugeot 406 and have just bought my second one, a Rapier Estate. What would cause a high pitched whine on acceleration on all gears? There is no whine with speed, only acceleration. This is the final straw with the 'new' car, after a string of problems beginning with a six car motorway accident in my Peugeot 406 Turbo Executive, which I adored and was written off. I am in despair now. Carol
Re: High pitched whine on acceleration in all gears
It could be all sorts of things, what have you already checked?
- Site Admin & Mad Biker!
What sort of engine has it got? My 406 Exec turbo whistles when I accelerate but I think it's just the turbo spooling up
- Newbie
.steve_earwig wrote:It could be all sorts of things, what have you already checked?
Thank you Steve. Ooops, not mechanical, but this is a very loud distinctive screaming whine which gets louder the more you accelerate in all gears. It doesn't do it going down hill for instance. The garage isn't sure but think it is the Turbo. A neighbour says it is the fan belt but the whine is different to that. It has just had a series of repairs, lastly, the head gasket, a depressing story actually but we didn't have the usual A.A. check and its all a bit of a disaster. I collected the car from the garage thinking it had been completely repaired only to discover the whine.
- xplosiv
- 2.0 Turbo
Hi,
Check the Alternator belt, mine did something like this a while ago.
Andy
Andy
407 HDi 136 SE (Iron Grey)
Maybe's a Diff whine if its in all gears on acceleration?
Vehicles I own:-
Vehicles I own:-
- DaiRees
Is it a constant pitch whine or does the pitch vary. If it varies, does it increase with vehicle speed or engine revs?
- mjb
If you hold it at a constant speed at low revs then floor the accelerator, does the whine come in straight away, or when you feel the turbo kick in?
This could be the sound of pressurised air escaping fro the intercooler/hoses it's not unknown for the intercooler to leak and cause a whoosing noise. Worth looking at the IC/hoses for oil leaks as the air will blow oil out with it.
Otherwise maybe gearbox/dfferential but these are normaly trouble free here.
- Newbie
Thank you . The whine pitch varies depending on the depression of the accelerator. For instance, going down hill and gathering speed, no whine, up hill and accelerating, the whine increases. Thus, not speed dependent but acceleration affected. When I put my foot down, the whine gets louder and louder, higher and higher. I guess this is caused by the engine revs. (Not a female domain - help)DaiRees wrote:Is it a constant pitch whine or does the pitch vary. If it varies, does it increase with vehicle speed or engine revs?
- Newbie
Thank you Andy,xplosiv wrote:Hi,
Andy
I am technically out of my depth here so will pass it over to the 'men'.
- Newbie
Well, if I hold it at constant low speed, no whine. If I accelerate, the whine comes in straight away and gets louder the more I put my foot down, to a screaming pitch.mjb wrote:If you hold it at a constant speed at low revs then floor the accelerator, does the whine come in straight away, or when you feel the turbo kick in?
I'm afraid it's really difficult to diagnose a noise without actually seeing the car, although I can't help thinking if it was the turbo bearings it'd be siezed by now. So, this garage changed your head gasket and returned it to you with this noise yet they've failed to identify it, what are they called, John Wayne Auto Services? Well ok it's not impossible that it's coincidence but... Maybe you need to take it someone else, see if you can find one that's "female friendly" too.
- 2.2 16v
Is it the same in all gears? i.e.does it vary with engine speed or road speed ? Is it there just reving the engine in neutral?
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
- Newbie
Iff I drive the car with low revs in all five gears, the car is silent. After a short while (could be when the Turbo kicks in, I am not sure), the whine starts, high pitched and the more I accelerate, the louder it gets. It is the same in all gears. It varies with acceleration not speed, i.e. going downhill fast, no noise, accelerate uphill and its deafening.djp30djp wrote:Is it the same in all gears? i.e.does it vary with engine speed or road speed ? Is it there just reving the engine in neutral?
