2000 Pug 406 HDI (110) executive...
Was blissfully cruising along the M6 @ 65-70mph when all power went from the right foot, engine light came on, and i slowed onto the hard shoulder where i called the RAC, they said, will the car restart, it did, so i continued on my journey, about an hour later the engine light disapeared and the car has been running fine ever since.
Should i still get the car hooked up to a diagnostic's to see whats going on?
Engine died on M6?
- 2.0 Turbo
Re: Engine died on M6?
Do rac have diagnostics that can tell you i know the AA carry on board diagnostics and theyres is brilliant helped me resolve a couple of issues
- jameslxdt
you need to get the fault codes read, but that could be a throttle pot fault, rail pressure sensor fault or pressure regulator fault
- Newbie
cheers james, any idea what these will cost to put right?
Also i noticed in your signiture about the fuel cap, is there any way to fix this? I have to make sure there are two of us in the car when i need fuel, thankfully thats only once a month!
- 2.2 16v
Try this. viewtopic.php?f=2&t=4205
406 HDI Exec Estate (2 off) & 307CC HDI Cabriolet
