rear brake backplates
- 1.8 8v
rear back plates on my 4006 sri turbo are fecked and i need new ones as the handbrake shoes are not being retained properly in the right place making it quite dangerous to use at the moment
what i need to know is where i can get them other than from the main dealers
any help or info is much appreciated
Re: rear brake backplates
i doubt anywhere other than a main dealer would do them. have you tried a decent pug breakers for a second hand pair?
1990 205 gti16, xu9j4 power! graphite grey, white speedlines, 306 brakes, ice, half leather.
going to enjoy smashing ctr's
2000 d9 406 executive v6 estate with an auto box, bit of a hot hatch slayer ;) currently munching 'hot' hatches.......
- 1.8 8v
to be honest mikey i wouldnt bother with second hand ones due to the fact they are just made out of cheap crap
I had the same thing on my D8, never seen it before no matter how rusty the rest of the car. I tried to have them replaced by a local chap but it was all looking too expensive so I had the guy weld them up. They do look crap tho.
The wost thing is you'll probably need to get new hubs as well, it all ends up silly money.
- 1.8 8v
been quoted 156.40 for a pair of back plates what a f*cking rip off
and u can immgine my surprise and ehat i said to the dealer lol
but hey u get a nice shiney alloy bracket with each plate
Don't forget the hub bearings, I seem to remember they're about £90 a pop
(note to self: must clean up the D9's backplates)
- 1.8 8v
and why would i want hub bearings i aint gonna be removing the hub am i?
- 1.8 8v
You could always saw the backplates in half.
- 1.8 8v
i take it thats a yes to i have to remove the hubs then
It pretty much looks like it I'm afraid, the backplate bolts are hidden by the hub so the backplate isn't going to clear it. Haynes (Book of Lies) says the bearings will almost certainly be damaged by the removal process. I guess that means either the rollers will be graunched into their tracks or the bearing will actually break.
Unless I'm mad, of course.
