Is this diagnosis correct?
does anyone else have this experience and where can I get a good priced replacement?
slightly wrong, its only when the lift pump bearings are breaking up, nothing to do with the high pressure pumpmikey s wrote:thats quite common among many new diesels. its a combination of the lift pump in the tank and the main fuel pump. if the pump was on its way out it would become hard to start, really poor fuel economy and performance will really suffer.
its only the estate you need to remove the tank and exhaust to get to it, it just fits through the top on the saloonWelton wrote:Little 'bits' in the filter indicate the lift pump is breaking, I think these bits build up over a long period myself until eventually the pump craps out.
It would be best to change it now but it seems the only real way to do it is to drop the exhaust/tank etc.
Bit difficult to do at home, and you do need to flush the lines out![]()
Has the pump been 'grumbling' at all? I know mine moans a bit when it's cold when you first put the ignition on then other times it makes a nice even hum.
Guys - is it possible to drain some diesel out of the filter bowl to see if any metal bits come out with it? or do you have to get the lid off etc.?
