What's wrong with your Pug?
Re: What's wrong with your Pug?
Pull the connectors off the switches?
think i will change the switch on the handbrake,apparently a very cheap fix :P
574lk3r
Post by 574lk3r »
steve_earwig wrote:
574lk3r wrote:my friend suggests where i have so many led's that maybe there is excess power and thats why my indicators flash so fast?
Indicator relays usually go nuts when there's a bulb blown, I think it's a feature, so presumably it's not seeing enough current flowing through your leds and doing the same. I have a suspicion you might get frowned at during your next mot...
thanks for that,
ill check it with my mot guy b4 the next mot and swop em out for the mot if i have to,
but saying that my mot guy is my ex bro in law and can be more understanding, not to the point of law breaking, but is more lenient..
de-stress not dis-tress and deffinately not in dis dress.
Add another to my list, the indicator stalk has decided to jam :x
I took it apart & the contact is virtually worn away & worn the casing away. Another trip to the breakers :lol:
Love my car :lol:
574lk3r
Post by 574lk3r »
had a weird thing the other day..
the remote central locking stopped working,
brought new batteries, still dident work,
and the headlights kept flashing..
well the next day all was fine again.
very strange.
Well I fixed the stalk, it was a great botch out of necessity :lol:
The track that the indicator contact ran in has a gap in the centre with a plastic bridge. This had snapped causing the contact to get jammed. I had no epoxy to hand so I cut up a piece of an old araldite spatula to fit the gap & heated it up with a small hot air gun to shape it into the gaps. Dob of grease & it works perfectly!
To the previous poster; you can unsolder the plip buttons and pop them apart (very tiny bits inside though!) There is a concave disc which is sprung; this makes the contact. Clean it up with some isopropynol, also the contacts it mates onto. Re-assemble, resolder & job's a good'un. Very fiddly but saves a lot of anger pressing the button 'til you put your finger through the rubber outer! :roll: :lol:
mav
Post by mav »
teamster1975 wrote: Very fiddly but saves a lot of anger pressing the button 'til you put your finger through the rubber outer! :roll: :lol:
too late, my plip hasnt got either button anymore.
really should get a new 1, thumb hurts in cold weather now :(
mav
The answers no!
Now whats the question?
The plip on my D8 has one button, it got a bit tempermental but I found the little battery inside had got dirty somehow, cleaned it up in (yeah right, isopropyl alcohol my arse) šljivavica (I'm not insane enough to drink the stuff) and it worked fine. Trouble is the button still disintigrated. New one from Pug? Stuff that! It ended up getting fixed by a watch repairer.
I had to get a new innards for the D9's plip and that came with case and buttons, 'twas a bit pricy!
TooT
Post by TooT »
WHOOOOOOOOO got a new one.
Drive over bump 'low water light' comes one, drive over another bump 'low water light' goes out.
Dickie wire somewhere me thinks :frown:
TooT wrote:WHOOOOOOOOO got a new one.
Why can't I have some exiting warning lamps and messages :cry: I've not had any for a while :(
I wonder if there is any MFD messages that no one has ever seen yet.............
ANTI POLLUTION FAULT
HANDBRAKE APPLIED
LOW BRAKE FLUID
ENGINE TEMP TOO HIGH
FUEL TANK ACCESS OPEN
(elite club only)
RISK OF ICE
FUEL LEVEL LOW
Any more???????????? :cheesy: :cheesy:
Got to say apart from the low brake fluid warning which we all know is a dicky
switch so discount that ,and the ice warning which is normal i have never had
any warnings flash up at all (saying that with crossed fingers and touching wood) :P :P
I've got the ABS light (must check those connectors!) and the low coolant light (it isn't lying either!) Must fit a new radiator!!!
Previous owner had tried botching the bottom hose on and cracked the joint on the rad :shock: :evil:
I have to top it up every 2 weeks or so and I think the antifreeze is so diluted I'm risking it a bit!
:lol: :lol: :lol:
TooT
Post by TooT »
HANDBRAKE APPLIED Yep get this
LOW BRAKE FLUID and this
ENGINE TEMP TOO HIGH seen this a few times
FUEL TANK ACCESS OPEN (elite club only)
RISK OF ICE every day
FUEL LEVEL LOW nearly every day
5 out of 7. Is that good?
bargainbro
Post by bargainbro »
3 out of 7. Goddammit, what´s wrong with my Pug??? :cheesy:
mbell666
Post by mbell666 »
4 out of 5* for me
*hdi so not likely to ever over heat and i don't have the anti pollution FAP thing ( :) )
1997 Honda Prelude 2.2 VTi
