I have seen some offers for FAP cleaning. Is it effective or not good idea to try?
FAP cleaning
Re: FAP cleaning
Yes it's a good idea if you wish to leave the D.P.F in place,
Just make sure there a reputable company & read lot's of reviews & testimonials.
It won't be cheep for a quality job & best done off the car,
Don't believe the one's that state the inject a product into it & then rev it out the tailpipe
The problem is the ash left behind after the re-gens, this is what eventually blocks them up & to successfully
remove it you have to do it off the car & reverse clean it.
2006 BMW e61 535d m-sport
run's for cover
Re: FAP cleaning
I've not heard any feedback from this kind of service, so I cannot really comment other than it may be worth squirting some kind of lubricant on the 4 bolts that hold the FAP on - they can shear off.
Please let us know what you think of the service, good and bad, just for future reference
Re: FAP cleaning
What is the maximum life of FAP in practice? I know it is planned to work 100-200,000 miles. But is it possible to work e.g. 500,000 miles without cleaning or something similar?
Re: FAP cleaning
Definitely not without cleaning off the car. How often its needed will vary a lot depending on type of driving. Be aware it's normally the residue from the dpf fluid that causes it to block. Soot can be burnt off the residue can't.
Re: FAP cleaning
If I am not wrong, the FAP has some grid in the middle and it does the job. Why it is not removable and when FAP needs replacement to replace only the grid, not the whole body. It will be 2-3 times cheaper than complete FAP.
Re: FAP cleaning
The grid in the middle runs almost the entire length of the cannister - it's pretty much an integral part and I resorted to using an axe to remove it...!
You would need to remove the cannister anyway to clean it out, so no real benefit of having to then remove the grill part, even if it was manufactured this way - although some sort of deposit/return scheme would work I guess.
Drive in ( obviously in limp mode
) and get your blocked DPF removed and swapped for a cleaned out one, then drive home.
The old blocked one is then cleaned out ready for the next customer with a choking 406.
