Omg air bag..
NinoB
2.2 16v
Omg air bag..
Post by NinoB »
Please what is driver module trigger?.. I scan my car due to the airbag flashing on my dashboard, it shows that it was on left seat..I attached a photo.. Please what will I do? I check all the wires under the seat and I disconnected and reconnected it back..clear all the fault code but still is showing drivers module trigger open..help guys
frog
Re: Omg air bag..
Post by frog »
Better to use "PP2000" (Peugeot Planet 2000) to read the diagnostic codes, the general purpose code readers often produce a lot of incomprehensable output.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Re: Omg air bag..
Is yours an older 406?
Early models D8 have just one airbag trigger for the steering wheel airbag, and later models have 2 airbag triggers...
I assume it's the drivers airbag, they may be a break in the contacts - but as suggested PP2000 will pinpoint it for certain.
NinoB
2.2 16v
Re: Omg air bag..
Post by NinoB »
Its D9... 2001 executive model..may like you said at the steering wheel, please how can I loose the steering wheel and check the air bag?
NinoB
2.2 16v
Re: Omg air bag..
Post by NinoB »
Hi all I got to loose the airbag on the steering wheel.. Then I saw the the airbag connector is out.. So I put it back and drew back everything.. To my surprise the airbag light is still flashing on in the dashboard..when I scan it I got this message:
1. Drivers module trigger open circuit ..permanent fault.
2. Seat belt trigger open circuit.. Permanent fault.
So cleared it..the rescan again..to my surprise the fault keep showing..I checked under the seat and I disconnected and reconnected airbag connector and seat belt..scan again and the problem is still there..please can someone help me out?
frog
Re: Omg air bag..
Post by frog »
My experience with general diagnostic code scanners is that they usually cannot clear fault codes on these 406 models.
Better to use PP2000, that has always worked for me.
The fault codes might also clear themselves after a few rides, so you might also just wait for them to clear.
Current "fleet":
Previously owned:
NinoB
2.2 16v
Re: Omg air bag..
Post by NinoB »
Okay, still driving for now and waiting to see if it will clear anytime soon
frog
Re: Omg air bag..
Post by frog »
Fingers crossed :wink:
Here is a nice video of some-one who had similar problems and was able to solve them: https://www.youtube.com/watch?v=EyCN-LF4I9A
Current "fleet":
Previously owned:
NinoB
2.2 16v
Re: Omg air bag..
Post by NinoB »
Hello guys
Problem solved I loose the whole steering wheel.. remove the whole com 2000.. I use 3.3 ohm resistor to bridge the airbag connection, start d car.. airbag flashing disappeared.. then remove the resistor reconnect the steering wheel...start the car problem solved... thanks peeps
NinoB
2.2 16v
Re: Omg air bag..
Post by NinoB »
frog
Re: Omg air bag..
Post by frog »
Good! Thanks for the update and the pics. Very helpful!
Current "fleet":
Previously owned:
