Wanted Brake server for 2.2 HDI
benczuk
Post by benczuk »
My Brake pedal has decided to stop rising like it used to (it does come back up, but rather slowly)
Suspected culprit is the brake server so I am after a replacement) i had expected to just be able to buy one off the shelf, but the usual suspects (ebay, ecp) cant help.
2002 2.2 HDi no ESP
TIA
PeterN
Re: Wanted Brake server for 2.2 HDI
Post by PeterN »
I would suspect that the 2.0. one is the same and there must be plenty of those in the scrapyards. They rarely fail so you should be fairly safe getting a secondhand one. Check first to see that it has a vacuum supply.
Are you sure it's not just the pedal return spring at fault?
If you can lift the pedal and everything works as it should, I would try to sort the spring or add another.
I bought a brand new servo from the main stealers ( mates rates ) for about £100 inc VAT.
I was going to use donor cars but the ESP one is different to the non-ESP one..... :roll:
+1 on what Doggy says though, I'm not sure the servo controls how quickly the pedal rises..
benczuk
Post by benczuk »
Thanks guys,
Have checked Vacuum, will check the spring but the pedal is "heavy" to lift...
