Air Bag Fault
D4B
Air Bag Fault
Post by D4B »
Hi All,
I am posting this on behalf of fellow forum member Peter (Winchester area) who has an Air Bag light on.
My PP2000 today came up with this:
Where to look? Any advice gratefully received 8)
My other Peugeot was a D4B
Re: Air Bag Fault
PP2000 descriptions can be confusing, my best guess is It means the steering wheel airbag is failing the continuity test, (but freely admit it could just as easily be the drivers seatbelt pretensioner).....
Disconnect whichever one you find easiest to get to and see if the error message changes / you get another one. If it stays the same you have the culprit - plug & unplug it half a dozen times and it will probably clear.
Re: Air Bag Fault
Hi Steve, if the car is a later model then the drivers airbag should say either 'trigger 1' or 'trigger 2' so I'm guessing its the pretensioner too.
If you unplug the connectors, please make sure the key has been out of the ignition for a good 5 minutes first.
D4B
Re: Air Bag Fault
Post by D4B »
Thanks for the quick replies, hopefully Peter is reading this and can get it sorted now :)
