Non starter after battery change power saver mode
rupesmcd
Post by rupesmcd »
Hi all,
I have a non-starter. 2.2 HDi.
The car started sounding like the battery was missing a beat about a week ago- hesitant to engage stater motor, particularly when cold. Yesterday at my Mums it sounded like it was on its last legs, I was amazed it started to be honest. Unfortunately when i got home (from Mums- some 15 miles) I turned the car off outside our house in order to unlock the back door (of the house)- when I got back in to move the car to where i park it it wouldn't turn over, the starter motor limped a bit, then nothing. Dash lights were still on, interior lights and heaters, windows etc were still working. Anyway, I was now blocking the road, and a bloke turned up in a tiny fiat wanting to get through.
Bother.
He kindly offered to jump it- we connected it up, no joy- in fact things were now worse- 'entering power saving mode' had appeared. I ignored this warning- presuming it was actually trying to conserve power in order to start (more fool me).
He and I tried to push the car to where I park it (literally 150 yards away) but it's a big bird, and it got stuck on the corner where there is a slight up hill. He abandoned me at this point muttering about his wife and it going dark, and all sorts of helpful things. I ran to our friendly local mechanic round the corner and he gave me a jump pack- 'this'll get it going', he said. So, black to black, red to red, away we (don't) go. :cry: car still beached in the lane at this point, 'entering power saving mode' not good.
Mechanic then came with his Vitara and he and I had a merry few minutes dragging my nice car around trying to get it out of the way and parked, unfortunately it did roll into a wall when i was in control of the brake (it was dark, wet, slippery, car had no lights, I must have pressed the accelerator and not the brake etc etc). There is now a ding on the rear bumper :frown:
Anyway i got it a new battery today and removed the old one. I am quite ashamed to say i didn't check any procedures before and just removed the old one and replaced it with the new one. We are now in power saver mode- no interior lights working, windows won't work, car won't start, 'entering power saver mode' displayed on the dash on ignition.
I tried a soft BSI reset after reading some threads- but I can't open the windows, so I don't think it has worked. Have i screwed it up? I am about to go and disconnect the battery- and will probably leave it disconnected until the morning. I have just the one key- and the fob doesn't work.
The car is a 2003 2.2HDi- defapped and remapped with Doggies magic file.
Surely I can still reset the system somehow? Will disconnecting the battery over night help? I could do with getting the windows to open to do the BSI reset procedure properly.
Any advice appreciated! I need the car this weekend really! It was a bit of a squeeze in the wife's 205 today (we have 3 kids....) :(
2003 Peugeot 406 SE Estate 2.2HDi De-fapped and re-mapped
1988 Peugeot 205 GR 1.4 petrol, smells right.
Re: Non starter after battery change power saver mode
If the lights aren't dimming out when you're turning the key then I'd think it's more likely to be the starter that's the problem. Jump starting these cars is a no.no, you can do all sorts of damage (it's in the knowledge base). Hopefully disconnecting the battery will help, you might need to give it a charge now too.
Hi mate, my old 406 did this twice.
Have a look at the back of the starter motor, its probably covered in oily gunk that get blown over it by a leaky air doser. It may be a new starter is on the cards, but its fairly easy to replace ( 45 mins ) and all should be well.
Will the car start with a bump start? Once the car has started the 'power saving mode' will disappear too.
If you have to do a jump start, connect red to red on both cars batteries, and blacks to the slam panels or similar, not on the battery.
You want a welding supressor across the leads, I wouldn't risk it otherwise. It might do nothing but...
rupesmcd
Post by rupesmcd »
Thanks guys. Starter motor- i bet that is what's up- it already had a new one a couple of years ago- but i guess if there is gunky oil getting on it it could have gone again- and there are definitely gunky deposits in that area- I'll check more thoroughly tomorrow. It also rings true with the fact that it wasn't really sluggish battery performance- but more of a struggle for the starter motor to engage/turn. At least I have a nice new battery now and (presumably) a perfectly good one in the boot too! :frown:
I'll start the ball rolling tomorrow with getting it replaced.
I replaced my starter the first time round with a second hand one from another member, it lasted all of 6 months before slowing down, struggling to start and then giving up on me when I was parked outside Tesco on double yellows.... :roll:
did you check the earth strap?
