***Wanted***Type C MFD Display***
Danlouiee
Post by Danlouiee »
MFD Screen type C that will support sat nav function..must have all parts and the sensors for remote and in good working order.
It is for my 206 GTi 180.
Dan
Re: ***Wanted***Type C MFD Display***
Isn't the 406 screen different to the ones in the 206? Or are you concocting something mysterious....
Danlouiee
Post by Danlouiee »
I have a demonstrator model 206 gti 180 with the Siemens screen it has the rare sat nav option with the remote but the screen has gone pixelated :( done some research and appears that its the same as the 406 :)
Have alook for a seller named Jez.s on ebay.
they repair them., £40 ish iirc.
Danlouiee
Post by Danlouiee »
Thank you have sent him a message hopefully comes back with some good news!!
Danlouiee
Post by Danlouiee »
Not so good news this was his response..
Hi Dan,
Thanks for your interest.
Sorry but on this occasion I can't help you.
I've done quite a bit of research on those units because they are quite rare and expensive. A while ago I actually bought a faulty one to see if anything could be done with it. When I took it apart the ribbon connectors that normally cause all the problems are not straightforward, they have chips embedded in the ribbons & I've not been able to locate any replacements anywhere (not even China), also after a lot more searching I found that there are two possible faults that can cause the same affect (lines across the screen & missing pixels, I'm guessing that's the problem with yours).
One is the ribbon connector & the other is the processor on the circuit board & there is no way of telling which is at fault.
Regards
Jes
The search continues!:(
