Intentional of course!
If it was laminated, that'd make it a far bigger envelope to put it in when loaned out!
Steering doesn't like water
Re: Steering doesn't like water
I had considered the possibilty that they may have been screwed down, but concluded that was unlikely due to the use of two bases, which implied a tacit acceptance of their limitations.markw wrote:Haha ...got you on that one....they're screwed down with a half inch self tapper through the middle! That piece of mdf will break before they come off!
"Dix points?"
It would be churlish to consider the limitations of any screwed fixing in mdf, therefore 10 points it is.
After all this, I'm fully expecting the OP to report back that he doesn't even have this type of power steering....
Would it matter? So long as the problem is sorted we can give ourselves another pat on the back for a job well done.
Besides, you're still going to have to explain that test set up gubbins to us whatever happens
Happily!
It's here for anybody with the variable set up to borrow.
