Hey friends , over the past week i have been having starter problems. For days the starter was getting weaker every day so i knew it was on its way out!
i check the battery voltage and charged it overnight many times with no change. after running the vehicle it was getting harder to start , but first start in the morning seemed fine. But over the last week it has gotten worse. One day i was stranded and i checked the starter and it was smokin hot so i cooled it down with a rag and some water and sure enough it cranked over and started, which got me home. I know that when the starter is hot there is more resistance thus needing more amps to crank, vicious cycle. Now all i get is a click and puffs of smoke!
I assume i need a new starter but just wanted to check here if i have missed something?
I have checked connections and ground and they are all tight and seem ok
What do you think?
Thanks Gray
In the middle of nowhere in the DR
Starter woes!
Starter woes!
Gray
2000 D9 2.0 litre RFV saloon
Re: Starter woes!
I think it's trying to tell you it's *****d
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Re: Starter woes!
Yes, I think you need a new starter.
Re: Starter woes!
It is a 45 minute job to replace a starter, no biggie really just stick to the 5 minute rule before disconnecting the battery.
Re: Starter woes!
Service box lists these starters for my car
2000 406 (RESTYLING) 4 DOOR SALOON 2.0 i 16v 135 4-SPEED AUTOMATIC GEARBOX RFV
STARTER MOTOR DETAIL MITSUBISHI M 000 T 85381
STARTER MOTOR DETAIL MITSUBISHI M 001 T 80082
STARTER MOTOR DETAIL BOSCH 0 001 107 063
STARTER MOTOR DETAIL VALEO (DEMARR) D 7 R 27
STARTER MOTOR DETAIL BOSCH 0 001 108 183
STARTER MOTOR DETAIL MITSUBISHI M 000 T 82081
STARTER MOTOR DETAIL BOSCH 0 001 108 176
STARTER MOTOR DETAIL VALEO (DEMARR) D6 RA 107
STARTER MOTOR DETAIL VALEO (DEMARR) D 7 R 26
But mine in the car is Valeo D6RA661?
what is the best match? will all work?
Having the starter rebuilt in Canada when i return shortly. Unfortunately Peugeot is not sold in Canada.
Anybody Know if these same starters are on other vehicles as well?
thanks
Gray
thanks
Gray
Gray
Re: Starter woes!
As far as I know these starter motors are the same for Citroen and Fiat, but I can find out tomorrow (monday).
Re: Starter woes!
Re: Starter woes!
hey guys
thanks for your help.
As i am back in Canada now i was able to get a new OEM Valeo starter for $165 US
Not a bad price at all!
Gray
