handbreak indicator and beep sound
relaxtrading
Post by relaxtrading »
Hi
I got this stupid light on off all the time making beep sounds. How can make it disappear ?
I tried removing the fuse but still on. Any help will be greatly appreciate
gumby6371
Re: handbreak indicator and beep sound
Post by gumby6371 »
Hi mate and welcome,
Model and year would be useful but I'm guessing its the switch at the base of the lever. Lots of info on here if you search but I'd need to know more details about the car to be sure.
2003 2.2 HDI SE
relaxtrading
peugeot 406 lx -19/01/2000 1761cc 4doors saloon petrol
thanks
Hi, welcome.
The chances are it is the switch at the base of the handbrake lever, under the centre console - but sometimes the light comes on and beeps for other reasons.
Is there anyone near you that can do diagnostics with PP2000 ( Peugeot diagnostic program )?
HI and welcome aboard. 8)
As the others have said, add your location - maybe someone nearby can help.
(You've had two posts approved now, so can you post straight away).
relaxtrading
hi
I live in kingsbridge, Devon. I want to fix it by myself, I can afford to pay anybody.
To me just get rid off the beep will be ok, because i checked with a mechanic and he said that the handbrake is ok.
thanks
gumby6371
Post by gumby6371 »
Most members on here are happy to help for a hearty handshake and a brew if your local, unfortunately your a bit far for me tho!
2003 2.2 HDI SE
Not sure about this, as I've no personal experience, but I think on early D9's there is a common warning light/message for both handbrake and low brake fluid.
(If anyone knows better, please chime in).
I suggest making sure your brake fluid level's ok before doing anything else.
The glovebox light switch is the same switch as the handbrake switch...
relaxtrading
I think is going to be better if just take off the fuse for the beep. Anyone know which fuse number and where is located?
thanks
Looks like it's either MF9 or MF12, you'll know you've got the right one when your dash stops working (i.e don't do it!)
trufflehunt
Post by trufflehunt »
relaxtrading wrote:I think is going to be better if just take off the fuse for the beep.
thanks
Well, you're wrong.
The microswitch that sits under the handbrake costs hardly anything at the dealers. The job to replace it is
straightforward. And once you've done it, the relief from having to put up with that really annoying beep
is quite enormous.
Why ask for advice, if you're only really interested in a bodge?
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
moodybluetwo
Post by moodybluetwo »
My switch went faulty twice....so I`ve disconnected it ....no light...but no noise or odd messages!
The switch/es are only a couple o quid. :D
hardly worth Moaning about. buy new one and replace.
pugph
Post by pugph »
Sorry I don't understand quite what you're saying. Is the light and beep on when the handbrake is on or off?
In my Peugeot owners handbook 2001 2lt, there is a paragraph about Beeping and low brake fluid warning!
Peugeot say that this warning is normal if the engine is running and the hand brake is on!
hope this helps
