Overhauled the rear brakes.
dirtydirtydiesel
Post by dirtydirtydiesel »
So nearly three weeks ago I jumped in to go to work, reversed of the drive as normal until I went to go forward, The rear brakes were locked solid :shock: ,
Draged her arse back onto the drive I went to work on my bike :frown: .
When I got home I jacked her up & wipped the wheels off O.M.G what a mess :oops: , Time for a rebuild me thinks :idea:
dirtydirtydiesel
Re: Overhauled the rear brakes.
dirtydirtydiesel wrote:So nearly three weeks ago I jumped in to go to work, reversed of the drive as normal until I went to go forward, The rear brakes were locked solid :shock: ,
So here's the result.
& just for good mesure while at it I replaced the top links :)
Last edited by dirtydirtydiesel on Thu Feb 13, 2014 11:48 pm, edited 1 time in total.
markw
Post by markw »
If you don't mind me saying, the first set of pics show a shocking lack of maintenance.... :o
The second set restores my faith in the home mechanic! Nice Job :cheesy:
Wow! nice repair.
Well done sir, qualifies for the detached handbrake shoe tee shirt. (Oddly, mine hasn't turned up either). :roll:
That's an excellent top link piccy, seems we're always trying to find one for someone......
What did you paint the disk (disc?) with?
rwb
Post by rwb »
Very nice job
oldskoolskool
Post by oldskoolskool »
Seems to be a common problem with these cars, just done mine including cables, but must admit I'm a little jealous as I didn't have enough time to paint my shields :-[ nice job there.
Sent from my HTC One X using Tapatalk 4
2003 - Aegean Blue - 2.2L HDi - S
Nicowico pipes, de-fapped, de-egr, K&N, pipecraft stainless exhaust, Re-map, paddle clutch & SMF, Nakamichi cd400, 5000k hid's & led's
Styled by piniferina, modified with shopping trolleys and car doors.
I reckon there's a trend to use too big a brake on cars these days just let the ABS/TC sort it out (it does seem daft to use the same brake across the range so you have the same set up as a V6) so, unless you hoon around like a nutter they just don't get hot enough to vaporise any water/condensation and end up in a worse state than, umm, the US.
Sent from my large colon using my bum hole.
dirtydirtydiesel
markw wrote:If you don't mind me saying, the first set of pics show a shocking lack of maintenance.... :o
I know Mark :oops: , I've only had the car for four months & I knocked the price down partly due to the state of the rear brakes.
Now beleive it or not the car has only covered 81k, one owner from new with a F.P.S.H :shock: , say's a lot for main steelers eh!.
Last edited by dirtydirtydiesel on Sat Oct 05, 2013 2:40 am, edited 1 time in total.
dirtydirtydiesel
Captain Jack wrote:What did you paint the disk (disc?) with?
Captain, I haven't painted the disc's they come like that, their Pagid & it's a anti-corrosion coating which is also supposed to help with bedding in :wink:,
For my money their the best std replacement disc's money can buy & not a bad price either :cheesy: .
Last edited by dirtydirtydiesel on Sat Oct 05, 2013 2:41 am, edited 1 time in total.
dirtydirtydiesel
oldskoolskool wrote:Seems to be a common problem with these cars, just done mine including cables, but must admit I'm a little jealous as I didn't have enough time to paint my shields :-[ nice job there.
oldskool, I think the main common prob here is down to a lack of routeen maintinance :roll: , I read about lot's of people complaining that 406 hand brakes are week but mine is now unmoveable on four click's & I have yet to bed the shoes in to the drum's 8) .
The only reason for painting the backplates is if you look carefully in one of the pic's you might notice that it has some holes in it :cry: , & on finding out that it would cost me in the region of £250 for two back plates & two wheel bearing / hub assembly's.
I descided to try & make mine last a little longer, lot's of wire wheeling / grinding / rust treatment / fibreglass / highstrength enamell on the disc side & hamerite on the back & the result's you can see in the pic's, hopefully should last for at least a couple more years :wink: .
Not to mention the time spent refurbing the rear calipers, they have had a simler treatment strip / unseize / clean off heavy corrosion / rust treatment / paint silver/grey enamell / new slider & seal kit ect, ect: :supafrisk:
Last edited by dirtydirtydiesel on Thu Feb 13, 2014 11:52 pm, edited 1 time in total.
oldskoolskool
Where did you get the refurb kit for the calipers, mine hadn't seized but I couldn't slide the piston back when fitting new disc's/pad's due to bad corrosion. After pricing up new parts I found it cheaper to buy refurbished calipers.
dirtydirtydiesel
Ebay, £14.95 inc p&p but was just for the slider pin's & the seal's inc dust seal's, my one saving grace was my caliper piston's were in good shape 8) .
Just a bit corroided between the dust seal & the back of the pad ( where there exposed ) :cheesy: .
KozmoNaut
Post by KozmoNaut »
steve_earwig wrote:I reckon there's a trend to use too big a brake on cars these days just let the ABS/TC sort it out (it does seem daft to use the same brake across the range so you have the same set up as a V6) so, unless you hoon around like a nutter they just don't get hot enough to vaporise any water/condensation and end up in a worse state than, umm, the US.
I counter that as long as your brakes can fit inside your wheels, there is no such thing as too big a brake, you want as much braking ability and heat absorption as possible, in the unlikely event that you need to do several hard stops in succession. You can never have brakes that are too powerful, as long as they're set up to let you modulate braking force correctly. There is such a thing as over-boosted brakes, but that's mostly because it's an easy way to make brakes feel more powerful and secure. They're so much harder to modulate and make it harder to stop the car softly instead of jerking to a halt. So big beefy hardware, big rotors and big multiple piston calipers? Yes please. Artificially over-boosted brakes? No thanks.
The reason they put the same brakes from the V6 on the other models is to save money. Put the brakes you know can handle a V6 on the 4-cylinders and diesels, and you only have to certify one braking system and you save money on parts and tooling. I know I certainly don't hoon around like a nutter, and I've had no trouble at all with my rear rotors.
The handbrake is another story, though. I'm still waiting for my detached handbrake shoe shirt, too.
2000 406 TS4 2.2 saloon
