steering rubber gators
charliedog
Post by charliedog »
Hi,
Has anyone got any ideas on how this should be done, having no experience myself with this type of job on my Peugeot 406 diesel 1998 lx. Haynes manual not very helpful on this topic, Any help would be appreciated.
markw
Re: steering rubber gators
Post by markw »
Do you mean the bellow type things on each steering arm which are attached to the end of the rack at one end and the track rod at the other?
If so, to get those off you''ll have to crack off the track rod end ball joint, undo the joint off the arm, then slide the bellows all the way off the end.
charliedog
thank you for your help. Its the bellows/gaitors that protect the rack joints NOT the ball joints at the track rod ends that fits to the hub. How do i find out if my steering rack is of the variable or invariable type :?: :oops:
Charliedog
markw
Post by markw »
If you have access to Service Box, type in your VIN and under the 'Characteristics' section it will tell you. If you don't have such access, pm me your VIN and I can look it up for you.
Line 7 of Vehicle characteristics...
charliedog
markw,
vin VF38BDHXE80226237
REG; P450 RYN
thank you
charliedog
charliedog
How do i or where can i find
service box
thank you
jonsowman
Post by jonsowman »
jonsowman
Post by jonsowman »
Did it for you :wink:
markw
Post by markw »
@ charliedog
Sorry mate completely missed your post. :oops:
Many apologies....
