Short Shifter
CHP406
Short Shifter
Post by CHP406 »
Hey guys,
I've been searching and searching the web lately for a short shifter kit for my 406 2.0 petrol, after realizing a 12-13cm shifting throw is just a little bit ridiculous.. If anyone has or know of a short shifter kit and could point me in the right direction, that would be muchly appreciated!
Oh, and while I'm on the topic of shifting; I have been experiencing quite rough gear changing for a little while now and wondering what it could be. It just gets stuck a little bit, especially when I go from 3rd to 2nd, it also gets stuck and wont go into reverse unless I re-engage/disengage the clutch. Most of the time it goes into reverse but has a crunch. I wouldn't of expected this from a car that has only done around 32000kms (20000 miles).
Thanks!
madmadmax
Re: Short Shifter
Post by madmadmax »
i have looked around and come to the conclusion that i will have to design and make one, there are that many about
Re: Short Shifter
There was a thread a while ago about simply removing the gear knob and cutting down the stick with a hacksaw - making a kinda short-shift??
CHP406
Re: Short Shifter
Post by CHP406 »
GingerMagic wrote:There was a thread a while ago about simply removing the gear knob and cutting down the stick with a hacksaw - making a kinda short-shift??
Well it would shorten the shift a bit, but I'm thinking more of a quick-shift kit. I'm quite sure it's got something to do with the pivot point of something on the shifter making it shorter to shift into gear.
CHP406
Re: Short Shifter
Post by CHP406 »
madmadmax wrote:i have looked around and come to the conclusion that i will have to design and make one, there are that many about
How will you go about that?
madmadmax
Re: Short Shifter
Post by madmadmax »
i have absolutely no idea i need to get hold of the gear stick and have a look at one first then see about adjusting the pivot points and leverage
V6Exec
Re: Short Shifter
Post by V6Exec »
Should be easy to design - implementation may be harder
406 Coupe S HDi
PP2000 clone interface
Re: Short Shifter
If irember corectly this dude had a short shifter
See link
http://www.nopoet.pwp.blueyonder.co.uk/
Send him a email and ask where he got the kit from :idea:
madmadmax
Re: Short Shifter
Post by madmadmax »
depends on what gear linkage you have if its cable or rod if its rod then you could try one from the 306 or 405, the cable linkage short shifter needs to be made
Re: Short Shifter
The 306 ones are a totaly different set up as far as I can see,
I took one of a xzara..today same set up as the 306
From the look at it they can be modified easily with a decent vice,
