406 non-runner
kevinday284
406 non-runner
Post by kevinday284 »
hi guys
my 406 was running ok then one morning it would not start I gave it a jump start and she fired up and since then ive had not luck getting her started I called AA 1st time and he said it was the glow plug relay so I changed it and still the same so called AA again next other bloke came and the said I got a fault with the ECU coz got power to the glow plug relay and power to the 4 pin plug underneath the relay but no power to glow plugs he thinks the ECU is not giving the signal to the relay to fire up .
can anyone help please Very Happy .
cheers guys
madmadmax
Re: non 406 runner
Post by madmadmax »
is this a hdi if it is then its not the glow plugs, i would look at the in-tank pump.
Re: non 406 runner
Is the lift pump under the back seat priming :?:
If not check the inertia cut off switch
Then the relay next to the ECU,
kevinday284
Re: non 406 runner
yes its a 2.0 hdi 90 bhp and how would I know if the lift pump under the back seat and what relay next to the ECU and were is the inertia cut off switch I know I have a black bulb under the bonnet to pull diesel up from tank
cheers guys for ur help n this matter
Re: non 406 runner
Yeah, I ran my car with faulty glow plug relay for 3 years and it only had a little trouble starting in the winter.
In-tank pump would be my next step. Can you hear it whirring when you turn ignition on?
Re: non 406 runner
The inertia cut off switch is near the suspension leg
Passenger side, look near the battery,
Brown double relay, if its got one shouid be under the ECU cover drivers side
Cam side of engine,
Is the lift pump whirring when you put the ignition on. :?:
kevinday284
Re: non 406 runner
im will try in morning as disconnected the battery as I saw something on a other forum about reseting ECU if u disconnect the battery over night .
I will report back in morning and let u guys know out come
thanks for all the help :D
Re: 406 non-runner
Is this a Siemens or Bosch? The reason I ask is if it's a Siemens it doesn't have a lift pump.
kevinday284
Re: 406 non-runner
hi steve yes it is a siemems ECU so it don't have a lift pump
Re: 406 non-runner
Can you check whether you have fuel flowing to the injectors? Disconnect one of the return pipes and crank the engine - you should see fuel trickling out of there.
kevinday284
Re: 406 non-runner
thank you captain jack I will try that .
I thank you guys & girls for all your help its been a great relief that I've come on to this forum and getting great help and advise for you all :D
kevinday284
Re: 406 non-runner
the latest on the non runner !!!!!!!!!!!!
got no brown double relay
can't find the inertia switch by passenger side
and got fuel thou to injectors
had battery disconnected for over 24 hours to try and reset ECU and nothing im now lost in what to do next :? :? :? :?
Re: 406 non-runner
Can you post up a PIC of under the bonnet mate,
I'm pretty sure it shouid have a inertia switch :?
kevinday284
Re: 406 non-runner
ok lozz I see if can post one up I got a local mobile mechanic coming this afternoon to diagnostic test on car
kevinday284
Re: 406 non-runner
here the pic's lozz
