12 year corrosion warranty?
So apparently 406's get a 12 year corrosion warranty? Does that mean that the mild rust bubbles on my bonnet lip can be repaired for free under Peugeot's warranty?
rwb
Re: 12 year corrosion warranty?
Post by rwb »
*** gets in queue
if it does i shall be mighty pissed off cos mine is just in its 13th year :twisted:
It's probably one of those policies with diminishing value so you've only got £13.60 in the 'Bank' so to speak :roll:
Or it needed to be annually inspected by a main agent, they'll have some way of backing out of it, just you watch :roll:
Soooo, who's doing the asking?
Yeah I might!
There are usually 2 standard get out clauses. The first is that they'll only fix if it has actually penetrated the metal. Ford required a picture of the bodyshop man holding something through the hole when I tried to get a bit of bubbling sorted on my (at the time) 5 year old mk2 Mondeo.
The other is as already stated, that the car needed to be serviced by the main dealer & have a bodywork inspection carried out at the required intervals.
steve_earwig wrote:they'll have some way of backing out of it, just you watch
Policy Exclusions:
No.1: Stone chip damaged to paintwork excluded. :roll:
