Hey guys.
I got a new air and oil filter along with a few other bits and bobs for my '97 406 (2.0, saloon) for Crimbo.
I go to replace the filter a few days ago and the new one has a grey foam pad stuck to it whereas the old one doesn't.
I checked this thread (didn't want to bump) and it seems like it should be there. Should I remove it or is was it an intended change? It it only intended to be used on the later models?
I think I read somewhere else about the filters getting wet and the foam stops it from flying into the engine, but the foam doesn't seem too tough. Could just be being paranoid.
On another unrelated note, the near-side pipe from the radiator to the engine is pretty rusty. I gave it a coat of old oil (from the oil change) in the meantime, but is this an expensive and/or easy part to replace?
New air filter
- lozz
Re: New air filter
Hi.
Air filters are never identicle, ive found afew that have the extra foam and others that dont,
iwouidnt worry about it unless there was aproblem with getting it to fit in place, (The extra foam wouidnt stop water ingress,ivery much doubt )
Bottom hoses where they clip into the rad can break off,
iwouid leave it alone unless its leaking, not sure on how much they are but ipresume they wouid be slightly expensive for what they are
as some forum members have Bodged theres in the past,
- 2.0 Turbo
Re: New air filter
the foam is there as extra dust protection
