wiper relay
wiper relay
Anyone know if the wiper relay is the same in d9 as the d8.
Re: wiper relay
It's not
In the D8 it's a unit under the steering wheel, whereas in the D9s it's integrated into the BSI iirc.
Re: wiper relay
Ok cheers bud.I took mine out and popped off the case to see if there were any obvious dry joints on the terminals ,but can't really see anything.should it be quite obvious if there is one, or should I just run the soldering iron over the terminals just in case.
Re: wiper relay
When you say you popped the case off, do you mean the bsi case to look for the wiper relay and if so is it easy to do?
Just as I'm havin probs with my wipers
Re: wiper relay
It's a D8:
Dry joints aren't always easy to spot, even using an eye glass. It might be worth running the soldering iron over it.loadlugger wrote:...my p reg 1.8 16v petrol...
