206 wheels on 306
206 wheels on 306
anyone know if 206 wheels will fit on 306.
spotted these,
ithink there 17" vortex
was there any other pugs other than 206 that had the vortex ?
grasmere59
Re: 206 wheels on 306
Post by grasmere59 »
I always liked the cyclones on the 306.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
grasmere59 wrote:I always liked the cyclones on the 306.
cyclones look alright but ican only find 15" one's.
KozmoNaut
Post by KozmoNaut »
The offset won't be quite right, ET is 25 on a 206, 15 on a 306.
If you wanted to fit 306 wheels on a 206, you could use spacers. You'll probably get rubbing by putting 206 wheels on a 306.
2000 406 TS4 2.2 saloon
KozmoNaut wrote:The offset won't be quite right, ET is 25 on a 206, 15 on a 306.
Thanks.
RobTurbo
Post by RobTurbo »
Cyclones were only ever 15", Lions look the same or similar and are 17" but very rare.
ive looked all over for Cyclones, bigger than 15s. n all :oops:
spotted some wheels on a 307 in the local breakers yard iwill try one on see if they fit,
The cyclones, dont luck much differnt /better to the standard lazer wheels whats on now,
so not much point getting a set of 15' them, shame they didnt make them in atleast 16s :(
madmadmax
Post by madmadmax »
i think you need 5mm spacers but i may be wrong have a look on pug306.net or 306oc
madmadmax wrote:i think you need 5mm spacers but i may be wrong have a look on pug306.net or 306oc
Thanks,
any ideas where to get spacers,?
RobTurbo
Post by RobTurbo »
The ones on a 307 are challengers, look the same but are a bit narrower, don't have solid centres and the offset is different, I have a set in the shed waiting for a refurb and tyres!
Cheers,
just been and had alook at the 307 wheels in the Scrapyard,
one of them was Mangled on the inside,
he still wanted a 1ner for them so left them there, by the time theyve been refurd and tyred up it wouidnt be worth it,
