idle fine but won't rev
Re: idle fine but won't rev
If it's an automatic then it doesn't have a flywheel as such, but it does have a ring gear around the plate the torque converter is bolted to and I'm referring to the teeth on this. What I'm thinking is that if some of the teeth are damaged they might be good enough for the sensor to get a strong enough signal at idle but it might start missing some as the engine revs increase.
- lozz
Have you checked the Metal plate, that bolts between the engine and the gearbox, the S/plate,
if the gearbox as been removed is it possible thats been bent alittle and is interfering with the signal of the crank sensor?
not sure if the 406s are inline with that but ive seen it happen with a few other cars in the past,
use a Mirror and a torch to eye ball that area,
- lozz
Edit: double post, internet lag".
bl4ckclio
thx 4 reply.steve_earwig wrote:If it's an automatic then it doesn't have a flywheel as such, but it does have a ring gear around the plate the torque converter is bolted to and I'm referring to the teeth on this. What I'm thinking is that if some of the teeth are damaged they might be good enough for the sensor to get a strong enough signal at idle but it might start missing some as the engine revs increase.
will check that soon.
bl4ckclio
will ask my mechanic to check your idea.lozz wrote:Have you checked the Metal plate, that bolts between the engine and the gearbox, the S/plate,
thanks.
bl4ckclio
if the plate has been bent, wont it will make some mettalic noise?lozz wrote:Have you checked the Metal plate, that bolts between the engine and the gearbox, the S/plate,
bl4ckclio
testing the fuel pressure.........read 3 bar.!!steve_earwig wrote:Hi there![]()
Perhaps you trapped a fuel line and there is only enough fuel to idle? Can your mechanic test the fuel pressure while the engine is running?
Where did you measure this?
bl4ckclio
at peugeot workshop in my country.steve_earwig wrote:Where did you measure this?
Argh! From the tank pump or at the filter?
bl4ckclio
no...steve_earwig wrote:Argh! From the tank pump or at the filter?
they connected the gauge at hose before fuel rail.......
So this is the pressure from the lift pump or the HP pump? If it's from the lift then it's certainly enough pressure, but then why does the fuel dribble out of the injector line? If it's the HP pump then it's a dead dog
bl4ckclio
sorry I didn't knew exactly how...steve_earwig wrote:So this is the pressure from the lift pump or the HP pump? If it's from the lift then it's certainly enough pressure, but then why does the fuel dribble out of the injector line? If it's the HP pump then it's a dead dog
but I think that's standard procedure for testing fuel pressure.
bl4ckclio
update:
try to drop the gearbox (again)
can someone analyze what's wrong with this ring gear?
no missing teeth
just some bent, which I give white arrow.
just hit with hammer to turn it back to it's shape......can I?
no missing teeth
Ah, so that's how it's done. I can't imagine that would cause any problems but I see no reason why you can't carefully straighten it.
