According to my son the DMF is a problem on those and the DPF clogs up on short journeys (nothing new there)
Bailes1992 wrote:The Rdeisgn is a pretty low model actually. The Rdesign LUX is what you want. The normal Rdesign is very spartan on kit indeed!
My fathers V50 Rdesign on 104k on an 08 plate sold for £3200.
Saying that other than a load of stepped rear tyres (I believe Welly gets this fault on his S40 too) and a squekky clutch pedal it was okay! Lurrrvellyy creamy 5 pot too!
Personally I would get a slightly older but high mileage D5!
Yes it is the GDi, I'll take your advice on the Forte!jasper5 wrote:Yours is the GDi Mitsubishi engine?
One important tip with these engines, apologies if you already knew, they had a throttle body fault on these engines and the inlet manifold furring up with black gunge, you should fit a very good quality injection cleaner every 3 months to keep the engine healthy ....something like Forte.
I've done loads of those belts, very common problem.
Just a note to remember that my son is a mechanic at a Volvo dealer, so if anyone needs any technical info just ask.
