Squeaking from brakes while driving but goes when i brake
jason1987
Post by jason1987 »
thought it might be the pads sticking so i took them out and put some copper grease on but its still doing it, any ideas what it could be? is from the left side
ally406
Re: Squeaking from brakes while driving but goes when i brak
Post by ally406 »
Do the caliper pins move freely?
dieselink
Post by dieselink »
clean caliper pins and grease them well m8
jason1987
Post by jason1987 »
i just undid the bottom calipper bolt and pushed the caliper up, are you talking about different pins?
dieselink
Post by dieselink »
undo top one to,remove,clean and grease m8,when i say clean i meen with wet and dry paper/wie wool what ever u have.
jason1987
Post by jason1987 »
ill try that at weekend then, hope its not the rears as theyre harder to undo
jason1987
Post by jason1987 »
greased both bolts and still squeaking, dunno what else it could be? goes away when i brake so i dunno
dummysock
Post by dummysock »
In days of old, car brakes were equipped with "anti squeal shims " which you would apply copperslip to.
I suggest that you smear a small amount of copperslip on the back of the pads
jason1987
Post by jason1987 »
thats the first thing i did, unless its the rear brakes i can hear but i greased those when i did them
Jack the car up , 1 corner at a time and turn each wheel,
you shouid be able to work out which one is giving out the noise then,
have you just fitted new pads?
jasper5
Post by jasper5 »
Never put copper slip on the slider pins....copper slip will cause the sliders to stick.
Make sure the pads are completely free and clean up the pad surface with rough sandpaper....file a chamfer on the edge of the pads whilst they are out.
jason1987
Post by jason1987 »
it doesnt do it all the time tho constantly, i dunno if the car needs to be driven a while or what but its definatly not all the time to be able to diagnose by spinning wheel, na fitted new discs and pads all round atleast a year ago now, and only started doing it last month or 2 that i can remember
