Mines done 176 so had i better buy 3 lolmemphisto wrote:i got some from autoessive it hink it was £6 a can plus delivery
try there ?
used a can today but as its done 140k i think i need another one to get the full benefti.
EGR Cleaner
- plod
Re: EGR Cleaner
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: EGR Cleaner
But mines done 230,000 and it took one!
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Re: EGR Cleaner
Used another can on my new 406 today, with the same impressive results. Runs smoother and pulls better at low revs. Might treat it to another can at Christmas.
Re: EGR Cleaner
Why not just block the EGR and never have to worry about it again?
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
Re: EGR Cleaner
Because I think it's better left as it came out of the factory. And it warms the engine up quicker to.406loon wrote:Why not just block the EGR and never have to worry about it again?
- OdinEidolon
Re: EGR Cleaner
dummysock wrote:Hi
Check out this video especially at 9 minutes in.
http://www.youtube.com/watch?v=1DhYk3Mm8HQ
That's some smoke but what scares is the noise!
- Bailes1992
Re: EGR Cleaner
Anyone else tried this? Wondering if I should just do it the proper way and remove it from the car to clean it or not.
Bailes.
Bailes.
- rwb
Re: EGR Cleaner
Have you seen the video?
Looks like a bad idea to me because:
- running with the air filter off seems a bit risky,
- all that crap has to go through the engine and cat
- you should make a how to
- rwb
Re: EGR Cleaner
because I've finished the gin and that's all that was handyrwb wrote:However, I am currently enjoying a bottle of wynn's diesel injector cleaner
- Bailes1992
Re: EGR Cleaner
I'm thinking of fitting a water injection system which should keep everything clean anyway.
The diesel knock on that Focus sounded chronic! Really wouldn't want my 406 sounding like that!
I'd love to remove the inlet manifold and the EGR. Clean and polish the manifold and clean out the EGR but afraid I'd break something
- OdinEidolon
Re: EGR Cleaner
+1 we need an how to on that.Bailes1992 wrote:I'm thinking of fitting a water injection system which should keep everything clean anyway.
The diesel knock on that Focus sounded chronic! Really wouldn't want my 406 sounding like that!![]()
Re: EGR Cleaner
Whatever caused that over reving, it wasn't the egr cleaner. We use it at work lots of times, and it has never done that.rwb wrote:Have you seen the video?
Looks like a bad idea to me because:However, I am currently enjoying a bottle of wynn's diesel injector cleaner
- Bailes1992
Re: EGR Cleaner
They revved the engine to show all the crap it cleaned out.Busman wrote:Whatever caused that over reving, it wasn't the egr cleaner. We use it at work lots of times, and it has never done that.rwb wrote:Have you seen the video?
Whats nasty is the high pitched knocking which is predetonation within the cylinder of which can actually over time cause bent conrods.
- Newbie
Re: EGR Cleaner
Just wonder if 99 td 1.9 engine has any electrical sensor or connector on egr valve? If its removed would it trigger engine management? The only one way to clean a egr valve is to remove it n soak it in petrol and hand brush it till u can see its clean again, if uve done that before u will know how bloody dirty they are and no quick spray can 15 mins job can do that. Ondby doing that u can see if the valve spring is working n if the valve is opening n shutting cos a clean faulty valve will smoke too.all diesel i had in the past i removed all their egr valves so no more smokin problem, need to find out if i can do that on the pug
