3.0 v6 starting problems
- Newbie
hi guys im new to the site and new to 406's i got my first one yesterday but im havin a issue with it.i go to start it and it does not start straight away i have to continue to turn it over for about 20 seconds before it either fires up fine or i have to tap the throttle a bit.this morning i got in it and it was icy outside and it started perfectly.but then later on i tried and it took ages again.the funny thing is its perfect when hot.please help me before i get put off pugs for good lol my gti6 blew up in two days of having it lol.any help muchly appreciated cheers
- mjb
Re: 3.0 v6 starting problems
D8 or D9?skywalker125 wrote:hi guys im new to the site and new to 406's i got my first one yesterday but im havin a issue with it.i go to start it and it does not start straight away i have to continue to turn it over for about 20 seconds before it either fires up fine or i have to tap the throttle a bit.this morning i got in it and it was icy outside and it started perfectly.but then later on i tried and it took ages again.the funny thing is its perfect when hot.please help me before i get put off pugs for good lol my gti6 blew up in two days of having it lol.any help muchly appreciated cheers
If it's a D9, chances are your battery's no longer giving out enough current to cold start. Usually there'll be an orange light in the bottom left of the dash with a picture of a key and a square.
If it's a 192bhp ES9J4 engine (doesn't apply to the 210bhp ES9J4S) and you can crank it for as long as you like but the *instant* you push the throttle it comes to life, then it's probably the ICV.
- Newbie
Cheers bud i cleaned icv but still no luck.any other ideas?
- Newbie
Also it has cut out twice wilst at traffic lights and it took like two minutes
to start .still puzzled
- Bailes1992
Idle speed control valve is goosed!
- Newbie
I take it the icv is the cynlinder next to the throttle body? If so whem i took it off and examined it it seemed to have loads of play in it rattly sound but i still cleaned it up . .so i take it there shouldnt be any rattleing am i correct?
- Newbie
sometimes hesitation aswell
- mjb
It should rattle, yeah, however starting problems and only cutting out at lights (or when the clutch is dipped while coasting) strongly suggests an ICV problem. If you don't have access to suitable diagnostics (PP2000), I'd suggest splashing £20 here: http://www.ebay.co.uk/itm/330608084197 The seller is a good bloke - he's a 406 coupe breaker and usually has anything you'll need for a v6 engine at a good price if you send him a message.
The only other things I can think of are the throttle pot (could explain the hesitation) and the speed sensor (located at the top of the gearbox where the driver's side diff goes in).
Is there anything else at all wrong with the car's electrics? Wobbly gauge on the dash, AC cutting out, lights misbehaving, etc?
- Newbie
yer the heater blower is tempremental and the airbag ligh comes on now and then .ivenoticed the heater blower is something to do with a green wire under the glove box.if you move it it comes to life lol
