now i am led to belive that i have heated seats but do not have the switches in the car for them in place of where the switches should be i have 2 bits of plastic that look as if they are used to hold £1 coins
how can i tell for sure if i have heated seats and how can i install the switches ?
chili wrote:how can i be sure i will not fry my ass ??
Hahahaha
Actually I'd be grateful if someone could let us know which connector under the seats does what, as there's about 10 of the things under there, and mine doesn't seem to have stuff plugged into half of them!
I understood that the only heated seats were the Leathers.
I doubt that Peugeot would put expensive heated seat wiring and controls in a seat which would never be used
mjb: If you have memory seats you will have more connectors than non memories, there are loads of wires though as you say. When my seat heater stopped working I just wiggled ALL the connectors and it worked
Type in your VIN here: http://www.detali.ru/cat/pe/pe.dll
and you'll find out if you had heated seats installed at the factory or not, as well as info about all other options.
The heated seats are under Interior fittings / Heated cover for some reason.
Welton wrote: That is fantastic, where did you get that?
I got it off the Polish Peugot Club forum. Someone posted it there.
Now, considering that this is in fact a Russian address, I give no guarantees as to what they do with our VINs afterwards.
This should be made a sticky on here.
Put it up as a new Topic, or I will if you want
Go ahead, being a newbie, it would take me days to decide which forum is the proper one to post such information. ;)
Well done.
Thanks, I thought it would be useful. But like i said, it's not 100% perfect. In my case it reports wrongly that I have ESP (which I don't) and that I don't have variable suspension (which I do).
Had to take my drivers seat out over the weekend to weld the subframe together, it had cracked in the bend and I noticed that there is 2 connections there that are not attached to anything, one is brown and one is white? any suggestions on what they are for? the cars trim is SE which means half leather and electric tilt height adjustment etc, it does not have memory seats or heated seats, could this be there use? of so how hard would it be to wire them up? is it just a case of fitting switches or would I have to wire everything through the fuse box??
Cheers in advance people
if you don't know where your going, any road will take you there
I've got a '99 GLX and I don't have electric seats but like you I keep finding extra electrics as well as lots of wires that seemingly lead to nothing. I was changing my temp sensor in my wing mirror the other day and found the electrics for heated mirrors, then I changed over my handbrake switch ( I had an earlier faulty one) and found three sets of wires in the centre console behind the cigerette lighter and before the airbag off switch that were unattached. Unsure as to what they are intended for.
