Another bargain!
rwb
Re: Another bargain!
Post by rwb »
Fancy a 607?
http://www.ebay.co.uk/itm/2002-PEUGEOT- ... 1e687cb1d4
and also at
http://www.tdmotors.co.uk/auction_detai ... tion_id=59
They look pretty nice, although this one has the poverty-spec mfd and somewhat excessive wood-effect.
Presumably the 2.2 will succumb to a doggy de-fap?
Postage £200.00
:shock:
Thats dirt cheap for such a big car, there is actually quite a few 607s round these parts all in some colour of blue.
I like the interior of them a lot, really luxurious and solid feeling, but the outside is a bit unusual
did the 607 ever sell with the v6 hdi over here?
These must be getting quite rare now:
1992 Peugeot 309 1.4, slight accident damage 300€
You after a 607? http://www.njuskalo.hr/auti/peugeot-607 ... as-3594742
Very nice. They're my Dad's favourite 5 Series. Personally though, I find the 525i a better all rounder & those double sunroofs are notoriously unreliable - proved by the fact that this one is knackered - & very expensive to fix.
I just like this version of the 5 series i also think it was the best, though here is something completely different:
http://www.carandclassic.co.uk/car/C251535#
£20,000 sounds expensive, but for a rally car its actually quite cheap.
Then the 505, there seems to be quite a few in australia, only just realising that they drive on the correct side of the road:
http://www.carsales.com.au/private/deta ... 7-11595150
FarmerPug wrote:I just like this version of the 5 series i also think it was the best, though here is something completely different:
That's only 30 miles up the road from me too.
you could go and have a test drive, i bet a t16 would live up to the drive of your life slogan peugoet used back in its time. :cheesy:
Something more appropriate to this site a cheap 406 hdi estate:
http://www.autotrader.co.uk/classified/ ... ?logcode=p
150k miles, tax+mot until next april. aircon problem, and dent in tailgate, but its only £595
FarmerPug wrote:150k miles, tax+mot until next april. aircon problem, and dent in tailgate, but its only £595
"slight bump in tailgate"? If that's a "slight bump" I'd hate to think what his idea of a minor whoopsie would be!
"needs re-gassing" = something expensive needs replacing
150k, £600 = clutch on its last legs, probably cambelt change required too
mjb wrote: "needs re-gassing" = something expensive needs replacing
Funnily enough I usually think the same when I see that in an advert. If a regas was all that was needed, you'd get it done as it's usually less than £50 & it makes the car easier to sell.
May not be the more sought after HDi, but this looks like really good value:
http://www.ebay.co.uk/itm/2002-PEUGEOT- ... 2c60d75e9a
Hmm going to have to get myself a '6 estate in next 6 months or so so we can go on honeymoon... Cheaper than rental and less stripsearchy than flying
Hoping I can find a suitable top trim pre-COM2000 D9, hdi90/136 or v6 for peanuts - something knackered but not too expensive to repair myself given enough time. Otherwise I'll just buy a £300 1.9/2.1DT and spend the time trying to get the stench out of the seats and carpet :lol:
its still cheap for an exec though, and if the clutch had to be done, it would be the perfect time to go on and take the engine out, do the timing belt, clean out the exhaust, check all the pipes are good, do the engine mounts, and a solid flywheel conversion. From the pictures the rest of the car looks in fairly good condition.
FarmerPug wrote:its still cheap for an exec though, and if the clutch had to be done, it would be the perfect time to go on and take the engine out, do the timing belt, clean out the exhaust, check all the pipes are good, do the engine mounts, and a solid flywheel conversion. From the pictures the rest of the car looks in fairly good condition.
Assuming it's just been properly serviced, nothing else is wrong with the car, you don't break anything fixing it, and all it needs is a cambelt, engine mounts, clutch and flywheel, you're still looking an easy £500 providing for that you use 2nd hand parts for the aircon.
I was actually putting some thought into it as a project for next year's trip (and as a keeper when the missus passes her test), but although it's cheap (not outstandingly cheap!) there's the cream interior which would need replacing because it's naff :lol: and the cost of doing the work... It'd also cost a fortune to get to Aberdeen to buy it :shock: I'll keep looking... :lol:
