speedometer wires
speedometer wires
Hi,
I need to find the Speedometer and the Rpm wires that goes from the dash gauges inside the car to the rpm sensor and the speedometer sensor ...
i tried to find in the internet but coulednt find nothing...
i need to wire it to my Haltech E6X harness ...
thanks,
thanks,
Re: speedometer wires
Hello, could you be our first poster from Israel?
Please help us out by telling us the engine and date of manufacture.
Hi,
yes i am from israel ...
hope to be the first but not the last
I have a peu 406 coupe year 1998 , and i am having some difficalt to installing the speedometer and rpm with my haltech E6X ...
Hmm, I think you've got a better chance with a D8 but it'll still make a difference with what engine it has - the ML gearbox has an interface for the speedometer under the glovebox, the BE doesn't. It will all be analogue but I can't tell you much else as I only have wiring diagrams for later multiplex cars.
You could also try asking this over on the coupé club (www.peugeot406coupe.com) as some of them are keen on doing strange things with their engines... Don't forget to tell them which engine you have and the year
Hi,
thanks for the reply , may be you can halp me with the harness that goes from the guges to the out side harness ,
das any one knows what is the wire colours of the speedometer and what is the rpm wire colours ??
this way i will be able to connect the haltech and the car together ...
thanks,
thanks,
You are determined to keep your engine a secret
These might give you some ideas:
Peugeot 406
RGX (XU10J2CTE) ENGINE - BOSCH MULTIPOINT INJECTION MP3.2F - http://peugeot.mainspot.net/wiring406/index.shtml
P8C (XUD11BTECY/L1/L3) ENGINE - EPIC DIESEL INJECTION - http://peugeot.mainspot.net/wiring406/p8c.shtml
I realise you are not looking at a diesel but the XUD11 uses the same gearbox as the ES9J4 so has the same interface.
Also Peugeot do not believe in colour codes - they use numbers.
Peugeot 406
[quote="steve_earwig"]You are determined to keep your engine a secret
maybe he has been trained to say nothing
whats a haltech anyway?
maybe its a need to know thing
prehaps i dont know as my security status is to low
Hey, there's this new thing, it's called a "search engine", you can put words into it and it'll search for these words across the entire internet - neat huh?
Seriously, it apppears to be a replacement ecu with lots of capabilities.
hi,
sorry about the missing data ...
im having trouble in rewiring the speedometer and the rpm to the car harness...
my engien is xu10j4 ... manual of course ... can some one help me in rewiring from the speedometer and rpm sensor to the car harness , i need to start from zero couse i replaced the car to haltech e6x ..
i need some diagram or something that will show me how to wire it from the begining ..
can someone help me in the wire colours ??
link for the haltech e6x :
thanks,
thanks,
Both sensors are on the gearbox. The speed sensor is accessed from underneath on top of the box where the right hand driveshaft goes in. It'll be covered by a fabric heat shield. The sensor responsible for RPM is accessed from under the bonnet and is located on top of the gearbox, slightly to the rear, where the gearbox meets the engine. It's a little black thing held in by a single 10mm bolt
Hi,
i allready know that... thanks any way ...
but some one can tell me what are the wires numbers that conect to the rpm sensor ? and for the speedometer ?
thanks,
thanks,
Possibly
RPM - 426
kph - 465
Looking at the XU diagram:
4210: tachometer (if separated).
4630: speedometer.
RPM - 426
kph - 465
4630: speedometer.
